cosworth parts for sale
lots of cosworth parts for sale in box me but not on much so text or call 07720758076
Cosworth Bits
5 x fly wheels two are lightened
Two WD two x exhaust manifolds with necks no cracks
Two WD 1 x exhaust manifold no neck
4 x4 1 x tube manifolds
3 door axel complete but no disks full pollybush with anti roll bar
5 x rear drive shafts
4 x4 inlet manifold 2 WD inlet manifold 2 WD half manifold
1 x Swedish inlet manifold with fuel rail
1 x 10 mm spacer plate
1 x 8 injector manifold ( home made but works)
2 x rocker covers 1 three door with breather other 4 x4
2 x sumps 2 wheel drive
1 x gearbox bell housing 2 wheel drive
1 x 205 block with dizzy drive and pulley
1 x 200 bottom end with crank rods oil filter housing oil pump dizzy drive and pulley
1 x fuel pump carrier
2 wheel drive head with BD10 IN + EX cams head ported and polished
2 pears front callipers four pots
4 x com rods
1 x crank shaft
2 x cam shafts IN + EX with bearings with cam gears
3 x water pumps 2 wheel drive
2 x two WD fuel rails
APR stud and nut kit
Fuel tank
3 Front ant roll bars
2 ally gear box mounts 2 metal gear box mounts
7 .5 in diff needs sun and planet gears
Kent cam BB15 ex or IN as new done 30 miles
2 wheel drive cam standard
4 x4 escort cam cover black with cosworth emboss
Valves inlet and exhaust 8 – 15 of each
X4 yellow injectors
X4 gray injectors
3 bar map sensor
Group A coil
L8 ECU think with P board L6 ECU with about 8 chips to go with ECU’s
Distributor 4 x caps 1 new 3 second hand but good HT leads
4 x 3 door step trim
3 door front door cards not brilliant + trim bits
3 door clocks good
2 x 2 wheel drive hubs + off side hub
5 x alternators
4 x 4 engine loom
Mongoose back box
Cross member 2 WD with rack
Bailey power steering pump alloy tank with P/S pump
3 door complete car loom
2 x 3 door wheels 1 needs wielding
Box of engine bits IE nuts bolts pulleys front casings dizzy drives cam pulleys oil pumps x3 , p/s brackets so on so on endless bits
Box of relays switches heater fans so on so on
Box of cabals so on so on
There probably lots more bits and bobs
Cosworth Bits
4 x com rods
1 x crank shaft
Fuel tank
X4 yellow injectors
X4 gray injectors
3 bar map sensor
Group A coil
3 door clocks good
5 x alternators
4 x 4 engine loom
Mongoose back box
Cosworth Bits
5 x fly wheels two are lightened £30 each or £45 for lightened each
Two WD two x exhaust manifolds with necks no cracks £60 each
Two WD 1 x exhaust manifold no neck £30
4 x4 1 x tube manifolds £30
3 door axel complete but no disks full pollybush with anti roll bar £350
4 x 2wd rear drive shafts £80 pair
4 x4 inlet manifold £80 2 WD inlet manifold £60 2 WD half manifold £30
1 x 10 mm spacer plate £30
1 x 8 injector manifold ( home made but works) £60
2 x rocker covers 1 three door with breather £80 other 4 x4 £80
2 x sumps 2 wheel drive £80 EACH
1 x gearbox bell housing 2 wheel drive £70
1 x 205 block with dizzy drive and pulley £200
1 x 200 bottom end with crank rods oil filter housing oil pump dizzy drive and pulley £700
1 x fuel pump carrier £30
2 pears front callipers four pots £70 A PAIR
4 x com rods £80 SET
1 x crank shaft £300
2 x cam shafts IN + EX with bearings with cam gears £50
3 x water pumps 2 wheel drive £10 EACH
2 x two WD fuel rails £10 EACH
Fuel tank £30
3 Front ant roll bars £30 EACH
2 ally gear box mounts £20 EACH 2 metal gear box mounts £10
7 .5 in diff needs sun and planet gears £70
2 wheel drive cam standard £20
4 x4 escort cam cover black with cosworth emboss £30
Valves inlet and exhaust – 16 of each £80
X4 yellow injectors £40
X4 gray injectors UNKNOWN IF WORKING £60
3 bar map sensor £60
Group A coil £20
L8 ECU think with P board £120 L6 ECU with about 8 chips to go with ECU’s £100
4 x 3 door step trim £40 PAIR
3 door front door cards not brilliant £ 30+ trim bits
3 door clocks good 170MPH AND BOOST £60
2 x 2 wheel drive hubs £60 + off side hub £30
5 x alternators £25 EACH
4 x 4 engine loom £80
Mongoose back box £60
Cross member 2 WD with rack £70
Bailey power steering pump alloy tank with P/S pump £80
3 door complete car loom £80
2 x 3 door wheels 1 needs wielding OFFERS
There probably lots more bits and bobs INBOX ME FOR BOX OF BITS IF YOU NEED SOMETHINK YOU NEVER NO MITE HAVE IT LOST BOLT CLIP SO ON
Fuel tank £30
Group A coil £20
rog
Sep 4, 2015 12:10 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
