Cosworth parts in now
loads of parts due in now
COSWORTH 2WD AND 4X4
we have a huge amount of COSWORTH parts in from
gearboxes 2wd and 4x4
heads
engines
crankshafts
cams bd10 bd14 bd16
ecus l1 l6 l8
injectors
starters
alternators
manifolds inlet and exhaust
fuel rails
regulators
diffs
beams
arms
shafts
ESCORT RS TURBO PARTS (ENGINES BOXES PANELS ETC)
FIESTA RS TURBO PARTS (ENGINES BOXES PANELS ETC)
2LITRE ZETEC BLACK TOP ENGINE
RS TRBO ENGINE AND BOXES
EFI INLETS
ECUS
heads
engines
crankshafts
cams bd10 bd14 bd16
ecus l1 l6 l8
injectors
starters
alternators
fuel rails
regulators
diffs
beams
arms
shafts
EFI INLETS
ECUS
CLOCKS Ł45
STEERING WHEEL 2WD Ł55
ABS ECU Ł35
LEVEL 6 ECU WITH STAGE 1 OR 3 CHIP Ł200
LEVEL 6 ECU STANDARD Ł185
LEVEL 8 ECU Ł245
RS500 GENUINE ECU Ł0FFERS
ESCORT COSWORTH SMALL TURBO ECUs Ł175
CLOTH INTERIORS Ł200
LEATHER INTERIORS Ł325
DARK CLOTH Ł250
CARPETS Ł35
DASHES FROM Ł45 COMPLETE 3 PIECES
VARIOUS PARTS OF INTERIORS ŁPOA
3DR INTERIOR PARTS ŁPOA
3DR ECU COVER Ł45
OUTSIDE
4X4 BONNET Ł130
FRONT BUMPER Ł200
FRONT BUMPER STRIP Ł15
BACK BUMPER Ł70
SIDE SKIRTS LESS JACKING COVERS Ł45
SHARK TOOTH WHEELS Ł200
BOOT LID AND SPOILER Ł75
SUNROOF Ł60
DOORS X4 Ł50 EACH
ELCTRIC WINDOW MOTORS Ł15 EACH
CENTAL LOCKING MOTORS WITH HANDLES Ł15 EACH
WING MIRRORS Ł15 EACH
HEADLIGHTS Ł30 EACH
BACK LIGHTS Ł20
BACK PANEL Ł15
FRONT INDICATORS Ł15
SIDE REPEATERS Ł10
GRILLE Ł45
REAR PANELS NEAR REAR SCREEN Ł10
WIPER PANEL Ł10
WHEEL NUTS Ł20 FOR 16
LOCK SET Ł35
ENGINE AND AUX
LOADS IN STOCK JUST ASK
STAINLESS EXHAUST 2WD AND 4X4 Ł200
205 BLOCKS FROM Ł125
2WD HEADS FROM Ł500
BARE HEADS 2WD AND 4X4 FROM Ł300
CAM COVERS FROM Ł75
THERMOSTAT HOUSINGS 2WD Ł25 4X4 Ł25
CRANKSHAFTS FROM Ł300
CAMSHAFTS STANDARD Ł50 PAIR
BD10 CAMS Ł150
FLYWHEELS 4X4 AND 2WD Ł45
DIZZYS 2WD AND 4X4 Ł35
LOADS OF ENGIE PARTS FROM PICK UP PIES TO PULLYS
GREEN INJECTORS Ł125
BLUE INJECTORS Ł50
YELLOW INJECTORS Ł35
3 BAR MAP SENSOR Ł45
THROTTLE BODY COMPLETE Ł100
2 BAR MAP SENSOR Ł20
CRANK SENSOR Ł15
WATER TEMP SENSOR Ł5
AIR CHARGE SENSOR Ł5
ALTERNATOR Ł40
ALTERNATOR BRACKET Ł15
PAS PUMP Ł35
PAS POLLY V PULLY Ł15
ENGINE MOUNTS Ł20 PAIR
IGNITION AMP Ł30
AMAL VALVE Ł30
SWIRL POT Ł45
4X4 INTERCOOLER Ł60
2WD AND 4X4 ENGINE LOOM Ł85
ALLOY RADIATOR Ł100
STANDARD RAD Ł60
FANS Ł40
COIL Ł15
SAMCO TURBO HOSES Ł70
SAMCO WATER HOSES Ł100
MAP SENSOR BRACKET Ł10
CAM BELT COVER 2WD AND 4X4 Ł45
AIR FILTER BOX Ł30
ABS UNIT Ł55
2WD / 4X4 CROSS MEMBER Ł40
VARIOUS HOSES ŁŁŁŁ
MOTORSPORT PLUG LEADS LIKE NEW Ł65
TRANSMISSIONAND RUNNING GEAR
4X4 GEARBOX Ł250
2WD GEARBOX Ł475
4X4 GEARBOX MOUNT Ł20
4X4 STARTER MOTOR Ł50
4X4 STEERING RACK Ł80
4X4 CLUTCH FORK Ł20
2WD CLUTCH FORK Ł25
FRONT DRIVE SHAFTS Ł100 PAIR
FRONT DIFF Ł75
FRONT SPRINGS Ł15
FRONT PROP Ł50
FRONT HUBS Ł100
FRONT BRAKE CALIPERS Ł100
FRONT GROOVED AND CROSS DRILLED DISCS Ł55 PAIR LIKE NEW
FRONT ANTI ROLL BAR Ł25
TRACK CONTROL ARMS Ł25 PAIR
FRONT ABS SENSORS Ł15 EACH
REAR ARCH COVERS Ł15 EACH
REAR PROP SHAFT Ł50
REAR BEAM Ł40
REAR ARMS Ł40 each
REAR DRIVE SHAFTS Ł100 PAIR
REAR SPRINGS Ł20
REAR 4X4 DIFF Ł150
REAR 2WD DIFF Ł185
REAR GROOVED AND CROSS DRILLED DISCS Ł35 PAIR LIKE NEW
REAR HUBS COMPLETEŁ90
REAR BRAKE CALIPERS Ł85
REAR ANTI ROLL BAR Ł25
ESCORT COSWORTH REAR ANTI ROLL BAR Ł60
REAR ABS SENSORS Ł15 EACH
HAND BRAKE CABLE Ł10
PETROL TANK Ł30
FUEL PUMPS Ł20
FUEL PUMP CRADLE Ł35
KONI SUSPENSION Ł150 SET
THERE ARE I AM SURE MISSED A FEW BITS TO LIST SO CALL ME.
I AM STRIPPING THE CAR SLOWLY AS TO PRESERVE THE CLIPS AND FITTINGS.
ALSO WILL HAVE NUTS AND BOLTS IF PEOPLE NEED THEM
IF WHAT YOU WANT IS NOT LISTED JUST CALL ME
ABS ECU Ł35
LEVEL 8 ECU Ł245
DARK CLOTH Ł250
CARPETS Ł35
3DR ECU COVER Ł45
OUTSIDE
4X4 BONNET Ł130
FRONT BUMPER Ł200
BACK BUMPER Ł70
SUNROOF Ł60
DOORS X4 Ł50 EACH
HEADLIGHTS Ł30 EACH
BACK LIGHTS Ł20
BACK PANEL Ł15
SIDE REPEATERS Ł10
GRILLE Ł45
WIPER PANEL Ł10
LOCK SET Ł35
ENGINE AND AUX
2WD HEADS FROM Ł500
CAM COVERS FROM Ł75
BD10 CAMS Ł150
BLUE INJECTORS Ł50
CRANK SENSOR Ł15
ALTERNATOR Ł40
PAS PUMP Ł35
IGNITION AMP Ł30
AMAL VALVE Ł30
SWIRL POT Ł45
4X4 INTERCOOLER Ł60
ALLOY RADIATOR Ł100
STANDARD RAD Ł60
FANS Ł40
COIL Ł15
AIR FILTER BOX Ł30
ABS UNIT Ł55
VARIOUS HOSES ŁŁŁŁ
4X4 GEARBOX Ł250
2WD GEARBOX Ł475
4X4 CLUTCH FORK Ł20
2WD CLUTCH FORK Ł25
FRONT DIFF Ł75
FRONT SPRINGS Ł15
FRONT PROP Ł50
FRONT HUBS Ł100
REAR PROP SHAFT Ł50
REAR BEAM Ł40
REAR ARMS Ł40 each
REAR SPRINGS Ł20
REAR 4X4 DIFF Ł150
REAR 2WD DIFF Ł185
PETROL TANK Ł30
FUEL PUMPS Ł20
Hi Gary. I have looked on yr forum but can't reply as it's not letting me on my phone. In pic 1 of the parts, there is a pair of fans in the top right. Are they slimline ones? If they work and are not damaged, how much are you asking (posted)? How deep are they at the thickest point?
Also, do you have a full set of Ahmed Bajoo springs? If so, posted price please?
cheeRS
cheeRS
ok guys some of you i have pmed
headlight wiper motor complete with wiper and arm Ł20 plus Ł5 post
fuel swirl pot sorry no
rear arch i will have to check but a pair have been sold
i have dump valves in stock and no GPa filters sorry
sorry no lHD cables
sorry no lHD cables
brand new Ł80
pulleys Ł65
leads Ł65
205 complete bottom end less suump and oil pump> completely rebuilt with new bearings and rebore> needs running in Łoffers
wernier pullys Ł40
set of verniers Ł75
brand new filter Ł80
stainless boost pipe Ł25
PAS alloy tank Ł45 SOLD
swirl pot Ł45SOLD
Bailey breather tank Ł65 SOLD
OMP boss Ł30
Air filter cover Ł20 SOLD
Wheel caps Ł20
Stainless covered clocks Ł50
Plenium spacer Ł30
MINT gearknob Ł30
pulleys Ł65
leads Ł65
wernier pullys Ł40
set of verniers Ł75
swirl pot Ł45SOLD
OMP boss Ł30
Wheel caps Ł20
Plenium spacer Ł30
MINT gearknob Ł30
Need original turbo coolant return pipe for a 3dr - alloy bit with the banjo fitting and the rubber hose to the header tank. Also the clamps that hold the pipe(s) to the top of the cam belt cover.
Also need a coolant level sender for a 3dr
Any possibility?
Any possibility?
