Was in my mates garage and came across a set of these cams, originally supplied by Dome Motorsport . Was wondering if anyone knew the spec on them? Cheers
Rally cams, mt23 is a nice rally inlet cam and the 21 I can't remember off my head iirc 23 is 11.25mm and 280ish deg duration I will check tomorrow on that and try find the info on the 21.
I imagine the 21 is a exhaust cam to match the inlet circa 9.5mm and 256deg
Ah thanks again, in essence fitting them to my 2wd then is going to be a nightmare especially when there is a set of 2wd specific mt22's on ebay at decent money?
