Escort Mk3/Mk4 Leda Coilover Suspension
I have a set of Leda Coilover Race/track suspension including springs
I have had fixed camber added to the fronts and all 4 were serviced by GAZ not long ago and not been used since
They come with Front coilover springs and rears springs are standard fit 700lb track springs
They were intended for my racecar but keeping my Ledas I have on there now
Please dont confuse these with Konis or Spax as these are the dogs danglies if you have a track car
£600 ovno
£600 ovno
Ah literally have just got a set of gaz golds being built but not that dort of poundage mine are 500lbs how big a difference would these make? Also how adjustable are they? They look very short are they designed for a low ride height?
To be honest that is cheap! Thats the other set that Kev was selling when i got mine.
Fantastic shocks indeed.
They look very short but i found that to be purely an illusion.....with 8'' 450 l/lb springs on the front and 8'' 275's on the rear i have to wind them all the way down to get a nice stance. Im considering 7'' on the front to combat this.
I honestly think the Gaz Golds are pretty much the same shock as lots of ex Leda staff now work there. The golds use a 2.5'' spring on the fronts just like the Leda's, the adjusters are nearly the same design and the shock bodies themselves apear to be identical.
22 Point adjustment also, be interesting to see how many incriments of adjustment the Golds have
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
