Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
pedal box into mk2
Old Mar 12, 2013 | 07:07 PM
jim cone's Avatar
jim cone
Default pedal box into mk2
hi just wondering how hard it is to fit a 3 pedal pedal box into a mk2? does it involve cutting and welding the car? want to fit one as much neater in the engine bay
cheers jim
Old Mar 15, 2013 | 12:16 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Not sure what you mean by " 3 pedal box " ?
Old Mar 15, 2013 | 01:10 PM
rs clint's Avatar
rs clint
insane
pedal box isn't in the engine bay think he means mk3 pedal box inside car ?
Old Mar 15, 2013 | 02:50 PM
ian sibbert's Avatar
ian sibbert
I think he means a 3 cylinder bias pedal box (clutch, front & rear), if that is the question, the answer is, you don't need to modify anything on a MK2 to fit a bias pedal box, the only negative about having this configuration is access to the cylinder when they are in situ, it is tight if you have to remove or do any maintenance on the cylinders....
Also take care with the selection of feed pipe you use, buy it from somewhere like Squires or West Wales or even better Gartrac...I've changed a when people have scrimped on rubbish pipe....
HTH
Ian
Old Mar 16, 2013 | 08:12 AM
rs clint's Avatar
rs clint
insane
got bias box in my mk2 2 cylinders as i have got cable clutch not hydraulic
Old Mar 16, 2013 | 03:18 PM
jim cone's Avatar
jim cone
ok cool yeah thats what i ment. so its an easyish fit? go a link to one? it will be running a type 9 box so what one would i need?
cheers jim
Kiran1600E
11
Oct 2, 2015 11:35 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
Sp3no
Sep 27, 2015 07:23 PM
Russ Payne
Sep 25, 2015 08:29 PM
