Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Steering noise
Old Mar 10, 2013 | 05:25 PM
zfocus's Avatar
zfocus
Default Steering noise
I need some help, Occasionally when i'm turning the steering wheel
i get a click sound come from which seems like inside the cabin
any ideas?
Old Mar 10, 2013 | 05:39 PM
phil_focus's Avatar
phil_focus
Been covered before but is it like this video?
Old Mar 10, 2013 | 05:42 PM
zfocus's Avatar
zfocus
Yeah it is like the Video, How can i fix this?
Old Mar 10, 2013 | 07:13 PM
phil_focus's Avatar
phil_focus
It's worth checking your universal joint on your steering column to rule it out but the cause of this fault is the steering rack. It will need replacing. Doable at home with axle stands if your handy with the spanners but if not then its a garage job as you have to drop the subframe.
Old Mar 13, 2013 | 08:39 PM
zfocus's Avatar
zfocus
Thank you for your help,
Any idea if i can get an after Market steering Rack?
Old Mar 13, 2013 | 09:19 PM
Colin_P's Avatar
Colin_P
Doubt it but there are plenty of reconditioned ones available.
Old Mar 14, 2013 | 01:41 PM
phil_focus's Avatar
phil_focus
The only racks I found were
Ford - stupicly expensive
motorfactors - recon racks that still looked expensive
breakers with 90 day warrenty - £65
I used one from a breakers and its been fine for about 18 months.
Try replacing the fluid, it might make it last longer, certainly did for me.
tankybaby66
Feb 6, 2016 02:24 PM
gingeRS
17
Oct 2, 2015 09:42 AM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
rsturbo27
Sep 5, 2015 05:08 PM
