Sapphire steering bush.
I have found the bush in the steering column under the exhaust manifold has play in it. Has anyone ever made a solid mount for this? If I did this will there be too much vibration through the steering wheel?
just fit a standard ford bush, they come to about Ł4 for all the bits you need
there has been a roller ball bearing used somewhere but i can't remember if it was a kit form or someone made one up
Cheers. I hope Ford down here in New Zealand can help. Otherwise it will be easy enough to knock something up at work. I just wondered if a solid one would be better with all that heat around it.
CozzyJeff done a bearing conversion on his moonstone 3dr maybe look through that?
https://passionford.com/forum/restor...ll-update.html
I got the land rover bush for mine i will have a look for the thread hold on
Edit found it
This is the thread
https://passionford.com/forum/ford-s...ring-bush.html
and this is what you need
http://www.island-4x4.co.uk/steering...78-p-1193.html
Edit found it
This is the thread
So the local landrover specialist wants $280 NZD for a used steering column. That's as close as I get. Another guy will do an exchange cosworth column for $180. I suspect it will have a ploy bush fabricated locally. It looks like the best option is to get the landrover one shipped from the UK but I bet the shipping for a whole column turns out to be expensive too.
The link above for island 4x4 offers worldwide shipping and part is only Ł25 I presume you don't have to pay the vat. Can't cost anywhere near what you have been quoted to get one over there.
Adam Graham
Sep 6, 2015 06:04 AM
