Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Dead Focus?
Old Mar 7, 2013 | 06:24 PM
m1ke's Avatar
m1ke
Default Dead Focus?
One of the girls at work drove in this morning with no problems in her mk1 Focus and went to leave this afternoon and nothing..
No dash warning lights, no odometer, not turning over but radio works, clock works, lights switch on and sounds door open buzzer so am I right in thinking it sounds like the ignition barrel/switch is at fault?
Cheers Mike
Old Mar 7, 2013 | 06:56 PM
Shifty Disco's Avatar
Shifty Disco
I'd say battery. When mine went flat it did the same thing, things would work but wouldn't turn over.
Old Mar 7, 2013 | 07:03 PM
Piston Broke's Avatar
Piston Broke
Try your battery terminals are clean are earths from the battery to the body are in good nick
Old Mar 7, 2013 | 07:04 PM
m1ke's Avatar
m1ke
Tried a booster on it at the time mate with the same result, cheers for the thought tho
Old Mar 7, 2013 | 07:08 PM
m1ke's Avatar
m1ke
Will check the earth too mate, cheers
Old Mar 7, 2013 | 08:53 PM
martysmartie's Avatar
martysmartie
This ^^, remove the battery terminals (Beware of radio code etc) although this is the least of the concerns at the moment and make sure they are free of corrosion and reconnect.
Martin
Old Mar 8, 2013 | 06:23 PM
m1ke's Avatar
m1ke
Will give the battery a look when I am back at work, thanks for the help
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Tank Mike
Sep 26, 2015 08:07 AM
