window switches
Old Mar 6, 2013 | 06:02 PM
t5frankie's Avatar
t5frankie
Default window switches
Are all sierra electric window switches the same? they look the same from the top, i need a set for my cossie
Old Mar 6, 2013 | 06:50 PM
mk22door's Avatar
mk22door
Fart of the Purniture
mk2 Sierra that had front and rear electric windows should be fine, XR, Ghia, 2000e etc.
Old Mar 6, 2013 | 08:05 PM
As said above.
Old Mar 7, 2013 | 12:26 PM
martysmartie's Avatar
martysmartie
Yes, so long as the source model has full leccy windows as said, and for extra points the rears are the same as a MK3 Fiesta
Martin
Old Mar 7, 2013 | 07:43 PM
mk22door's Avatar
mk22door
Have you no switches at all or they stopped working?
I took mine apart and cleaned them up, worked fine after that.
Old Mar 7, 2013 | 07:48 PM
dojj's Avatar
dojj
Resident Wrestling Legend
take them apart, they carbon up on the contacts and stop working
just be VERY CAREFUL when you pull it apart, the little bits go EVERYWHERE
Old Mar 7, 2013 | 08:11 PM
mk22door's Avatar
mk22door
They do!
But it's not a total nightmare.
Old Mar 7, 2013 | 08:40 PM
t5frankie's Avatar
t5frankie
the contacts were all fine, its just the drivers window that wasnt working
Old Mar 7, 2013 | 08:57 PM
martysmartie
Then it's most likely something else, i.e. motor or regulator?
The problem with the switches is A) the beeswax inside dries out and B) Fords lack of relay's means the entire load is switched via the switches which is what leads to the arcing etc.
Martin
Old Mar 7, 2013 | 09:13 PM
t5frankie's Avatar
t5frankie
Martin
no mate its the switch, i tested the drivers window wires on window 2 contacts and it worked
Old Mar 7, 2013 | 09:23 PM
martysmartie
Oh fair enough, cleaning the switch should sort this though as they only have sprung loaded copper tracks inside essentially.
Martin
Old Mar 7, 2013 | 09:24 PM
mk22door's Avatar
mk22door
You tested the wires at the switch end - I reckon you did? Did you?
Old Mar 8, 2013 | 06:45 AM
dojj's Avatar
dojj
Probably a broken wire onthe door loom a pillar sub loom
Old Mar 8, 2013 | 06:39 PM
mk22door's Avatar
mk22door
That dojj, is exactly what had happened to one of mine!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
