info needed brake experts
Old Mar 5, 2013 | 07:11 PM
tomoyb's Avatar
tomoyb
Default info needed brake experts
on sierra 1ts a 19mm nut for wheels so m12 threaded stud
so the hole size in discs especially alloy bells what should this be?
obviously 12mm drill bit will be too small
ive lined up an m12 bolt with a pair of reyland bells i have it fits through fine but with a bit of play around the thread
is this alright,because the other ones i have have had a 14mm drill to make holes and therfore a bit side to side play,the centre circle fits tight on hub okay but the disc will move a little left to right until wheel is bolted on and pushing it tight
is this dodgy
Old Mar 5, 2013 | 09:11 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Normal clearance hole for a metric thread is 0.5 mm, so for M12 it would be 12.5 mm. As long as the centre hole in the disc is a good fit on the hub spigot then it shouldn't cause an issue if the stud holes are a little large. The disc may slip round a little until the studs contact the sides of the holes but the disc will still be concentric to the hub.
Old Mar 5, 2013 | 09:32 PM
tomoyb's Avatar
tomoyb
thats what i was thinking
the centre hole is bang on with hub so no play there
it was just the play on studs,but i assume once braked hard thats it they are not going to move from there
Old Mar 6, 2013 | 07:46 AM
Brendan's Avatar
Brendan
struggling with reality
If you can find an old 1/2 inch drill that will sort you out at is is 12.7 mM
Old Mar 6, 2013 | 08:12 AM
tomoyb's Avatar
tomoyb
Thing is im useing the bells that have been drilled with 14mm drill
I think it will be okay
cos elle
Sep 1, 2015 06:48 PM
c20tbo
Aug 17, 2015 10:19 PM
track.focus'd
Aug 12, 2015 05:53 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
col93saphcos
Aug 7, 2015 03:21 PM
