cosworth fan direction
Old Mar 3, 2013 | 10:36 PM
tomoyb's Avatar
tomoyb
Default cosworth fan direction
just rewired fans with aftermarket loom
just want to be sure ive picked correct colours
when fans running and looking over slam panel
should they be going clockwise ir anti?
Old Mar 4, 2013 | 12:06 AM
Sonic Boom's Avatar
Sonic Boom
They suck air through the radiator so just stick your hand at the back of the fans and make sure you can feel air blowing towards the engine.
Rich
Old Mar 4, 2013 | 07:16 AM
tomoyb's Avatar
tomoyb
Yeah if im looking at fans you get the heat in your face lol
Old Mar 4, 2013 | 07:55 AM
Brendan's Avatar
Brendan
struggling with reality
The fans should pull cold air in through the front of the car!! (front to rear) as though the car is moving forward.
NOT push warm air out of the front! This will cause an air stall around the rad and the engine to over heat.
Old Mar 4, 2013 | 08:31 AM
tomoyb's Avatar
tomoyb
So if they are turning clockwise and heat is getting pushed up to slam panel area this is wrong direction?
Old Mar 4, 2013 | 10:31 AM
Sonic Boom's Avatar
Sonic Boom
If you put your hand between the fans and the engine can you feel air blowing?
Rich
Old Mar 4, 2013 | 08:12 PM
tomoyb's Avatar
tomoyb
I havent put my hand right behind fans but i can defo feel it blasting up the way so im assuming thats it going in correct direction towards engine
Old Mar 4, 2013 | 08:34 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Put a piece of tissue against the front of the rad/intercooler, the fans should draw the tissue onto the rad
Steve
Old Mar 4, 2013 | 08:37 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
agreed with steve,
ir if you know a dirty smoker, get them to blow cancer at the front of the fans and see where it flows to
Old Mar 5, 2013 | 09:04 AM
tomoyb's Avatar
tomoyb
Good idea only wont the 500 cooler obstruct this?
markk
Dec 2, 2021 06:59 PM
3dr cossie
11
Dec 21, 2015 03:38 PM
martysmartie
Sep 6, 2015 10:22 AM
hydro st170
Ford Focus ST
Aug 28, 2015 01:26 PM
Aug 14, 2015 07:29 AM
