mondeo tddi mondeo tddi vaccum noise when accelerating
hi, all im hoping someone can help me with my problem!!I have a vaccum noise when accelerating on my 51plate mondeo tddi,
is there anything i should be checking with regards to any pipe work?
thanks in advance
I forgot to say, the car starts and drive fine, apart from lack of power, and
thats i have no warning lights on dash!!!
You can see most of them from above. Just follow them out of the turbo, around the block, into the intercooler, then back out the other side.
This is for the TDCi but the layout is similar.
The 2001 TDDI will be a 5-speed, the boost hoses go over the gearbox, not under, so are completely different from that, that is a front mounted EGR, it might have a rear mounted EGR, which is totally different
The 2 hoses that split 1st are the one at the top that goes into the inlet manifold and the one below that near the bottom
Mostly, the hoses are accessable by opening the bonnet
have a listen with the engine running to help track it down
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
The Enigma
Sep 29, 2015 10:31 AM
