2006 2.2 Estate rear pads
Old Feb 23, 2013 | 03:32 PM
gtpete's Avatar
gtpete
Default 2006 2.2 Estate rear pads
Hi, in middle of changing my rear discs and pads (genuine Ford parts) The one of rear pads is chamfered at both ends the other one chamfered at the leading edge. I have assumed that the shimmed pad goes on inside against the piston, however Haynes manual says shimmed pad goes on outside? the old shimmed pad was fitted against the piston so was planning to refit them the same. Which way is correct?
Old Feb 25, 2013 | 04:07 PM
wulliegunn's Avatar
wulliegunn
I dont even bother wi shims.if you've got enough copper grease on backs/lugs,it'll be good
Old Feb 26, 2013 | 07:23 PM
gtpete's Avatar
gtpete
Default Rear Pads
I have called it a shim, but it is glued to one of the pads,
rex647
Mar 6, 2022 06:20 AM
yatta
May 21, 2016 10:31 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
cossirob
Sep 3, 2015 09:17 PM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
