Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Failed MOT due to emmisions
Old Feb 22, 2013 | 11:15 PM
Craig Duffy's Avatar
Craig Duffy
Default Failed MOT due to emmisions
Hi guys,
looking forward to participating in what looks to be a very busy community. however straight to the point...
My 2010 model Ford Fiesta Zetec failed its first ever MOT (obvcourse 3 year old car dont require MOT's) and to make things worst ive only had it 5 Months
My MOT emmisions results from 2 garages are as below :
max for CO should be 0.20%
max for HC should be 200ppm
GARAGE 2 (After bottle of Catcleaner)
Fast Idle Test
CO 0.30%
HC 348 ppm
Second fast idle test
CO 0.67%
HC 314 ppm
GARAGE 1
Fast Idle Test
CO 0.52%
HC 393ppm
CO 0.93%
HC 216ppm
Anybody advise on the steps to take to try resolve this isue?
I was told it could be the oxygen sensor (if anybody knows a rough price for one?)
regards
craig
Old Feb 23, 2013 | 07:16 AM
oldford's Avatar
oldford
It is always difficult to judge what is going on without further information.
The extra information would be the CO2 and O2 levels measured and the lambda number.
Based on the above figures I would say a defective catalyst.
Any fault codes present in the engine ecu?
What's the history? Any problems with sensors/spark plugs/coils?
How to test a catalyst: http://www.picoauto.com/tutorials/cat-efficiency.html
Old Feb 23, 2013 | 08:21 AM
Craig Duffy
Hi oldford,
sorry i only gave the results it failed it, all below results passed,
Lambda between (0.97 - 1.03)
CO Max - 0.30%
Garage test 2 (after catcleaner)
Fast idle test
Lambda 0.98%
second fast idle
Lambda 0.98%
Natural idle test
CO 0.29%
Garage test 1
Fast idle test
Lambda 0.970%
second fast idle
Lambda 0.970%
Natural idle test
CO 0.08%
No codes on dash, i think a gonna need a diagnostics £70
regards craig
Old Mar 17, 2013 | 01:30 PM
Craig Duffy
SOLVED
new spark plugs my car was mis-firing burning the wrong mixture of fuel.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
