2wd heat shield - painting it???
Old Feb 11, 2013 | 09:07 PM
K464TGV's Avatar
K464TGV
10 Year Member
Default 2wd heat shield - painting it???
Has anybody used any sort of paint on one of these?
I've just refurbished the turbo side with new aluminium self adhesive material and noticed a very small hole of the opposite side of the shield (the part that's all black fibre) and would love to use a small bit of filler to get rid of the hole then re-spray the whole of the black side for a freshen up, but don't want to use something that's going to ruin it....thanks in advance!
Old Feb 14, 2013 | 12:08 PM
opposite lock's Avatar
opposite lock
Maybe PM Harris on here i think he had one re covered/refurbished iirc.
Old Feb 14, 2013 | 08:26 PM
K464TGV's Avatar
K464TGV
10 Year Member
Thanks for the reply, I'll pop him a pm
now! All the best
Old Feb 23, 2013 | 12:58 PM
K464TGV's Avatar
K464TGV
10 Year Member
I managed to find out that high temp heat paint can be used on the heat shield and that holes can be patched up using exhaust filler/putty. I managed to add extra tape on the unaffected side to act as a way of preventing the exhaust filler from sagging through. Once set the whole black fibre side of the shield was treated to two thin coats of matt black high temp paint, after which the reflective side was completely taped up neatly with aluminium reflective tape. The shield looks like brand new and I don't have to worry about it setting on fire!
Old Feb 23, 2013 | 01:21 PM
Harris.'s Avatar
Harris.
Good stuff. It will be fine .
I cringe when i see people driving about without them ,mostly escort cosworths . You know its going to end up it flames
Old Feb 23, 2013 | 08:54 PM
johnnycortina's Avatar
johnnycortina
Thanks for this info - I have to do a similar repair on heatshield myself.
Old Mar 27, 2013 | 01:58 PM
jimhc's Avatar
jimhc
big jc
I have a st/st shield but dont like the bling so painted it with vht wrinkle paint from ebay that can take 350 df but turns out not for long sustained periods. Does anyone know what i could use (wrinkle affect) or do you think it would be fine?
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
cossie09
Sep 10, 2015 06:56 PM
hopper350
Sep 4, 2015 12:53 AM
