1987 Sierra Cosworth
Regrettably I have to put my pride and joy up for sale because I need the money for a deposit for a mortgage. I have owned this car for just over 5 years
I spent a long time looking for the right car and i'll be gutted to see it go. This car also comes with a huge amount of history and paper work, it has had no expense spared and has been very very well maintained over the years.
Car Spec....
The car is running 294bhp & 305lbs/ft @ 24psi
Engine Bay
T3 Turbo from CR Turbos
-31 Actuator
200 Block
4x4 Cylinder Head
4x4 Exhaust Manifold
Bayjoo Chip
Bosch Green Injectors
Marelli 3 Bar Map Sensor
Mongoose Exhaust System
RS500 Intercooler
Turbo Water Cooler
Group A Coil
8.5mm Magnecor leads
AP Organic Clutch kit
100% Carbon Cam Cover
Spec-R Header Tank
Spec-R Strut brace
Spec-R Turbo Heat Shield
Spec-R Power Steering Tank
Spec-R Swirl Pot
Spec-R Oil Separator
Spec-R Oil Catch Tank
Spec-R Dump Valve
Full Samco Hose Kit
Goodridge Fittings
New Fan Wiring Loom
Brackets, Pulleys, and other small parts have been powder coated
Koni Shocks
Clifford Concept 50x Cat 1 Full Closure Alarm
Interior
100% Carbon 3 Pod Gauge Holder
Auto Meter Oil Temp Gauge
Auto Meter Oil Pressure Gauge
Auto Meter Boost Gauge
S.E.S.C ECU Monitor
Retrimmed Half Leather Interior including door cards
Resent service items/parts fitted
Original Wheels refurbished in April 2012
4 New Tyres in April 2012
AP Organic Clutch kit in May 2012
Gearbox Oil & Diff Oil have been changed in May 2012
Engine Oil & Filter are changed every 6 months regardless of amount use
Gates Cambelt & Tensioner
All Oil Seals have been replaced with VITON items
Refurbished Rocker Cover
Cometic Rocker Cover Gasket
Cometic Half Moon Seals
Fuel Pressure Regulator
Dizzy Cap & Rotor Arm
Phase Sensor
Crank Position Sensor
Blue ECU Coolant Sensor
071 Spark Plugs
Rear Driveshaft Boots
Steering Rack Gaitors
I have proberly forgotten something but if you have any questions please call me on 07701024470
£16,000 ovno.
Car Spec....
Engine Bay
-31 Actuator
200 Block
4x4 Cylinder Head
Bayjoo Chip
RS500 Intercooler
Turbo Water Cooler
Group A Coil
Spec-R Header Tank
Spec-R Strut brace
Spec-R Swirl Pot
Spec-R Dump Valve
Full Samco Hose Kit
Goodridge Fittings
New Fan Wiring Loom
Koni Shocks
Interior
S.E.S.C ECU Monitor
Phase Sensor
071 Spark Plugs
£16,000 ovno.
Thanks guys
I may be interested in a PX + cash my way depending on the car so I've still got a toy for the weekends, something like a mk4 or mk3 RS Turbo or zetec powered mk1 Fiesta
fuck my old boots! thats immaculate! good luck mate.. i love the seats
Sorry Matt I know you was very interested but it just hasn't worked out but never say never
He's coming back in 2 weeks to collect the car, you never know he might change his mind by then
3dr cossie
11
Dec 21, 2015 03:38 PM
charliecosworth
Aug 19, 2015 02:00 PM
155lee
Aug 14, 2015 11:21 AM
