Sierra Cosworth P100 500BHP Big Spec Breaking
Engine :
200 Block,7.2-1 CR Pistons,WRC Long Studded Block, Lightened And Balanced Crankshaft And Flywheel, BD16 Cams, Double Valve Springs, Ported And Polished Head, 70mm Throttle Body, 8 803 Dark Green Injectors, S8 Programmable ECU, Water Injection, Custom 316 L Stainless Steel Exhaust, Custom Breather System.
Transmission :
4 Paddle ceramic clutch, Escort Cosworth Gearbox, Sierra Cosworth 7.5" Rear Diff, escort Cosworth Front Diff, Custom Shortened transit Prop Shaft.
Suspension :
lead tarmac Spec Adjustable Coilovers, Front Sherical Bearing Top Mounts, Gaz Custom rear Coilovers, Escort Cosworth Steering rack.
Brakes :
Brembo 8 Pot Calipers With 380mm Front Discs
Brembo 4 Pot Calipers With 310mm Rear Discs
Goodridge Brakes Lines, Cosworth Master Cyliner And ABS System, Hydraulic handbrake.
Exterior :
3dr Bonnet And Vents, Front grill, Front Wings, Shaved Door Handles, 3dr Front Arches And Skirts, 3dr rear Arches Modified, Yamaha Fazer Fuel Cap, Custom Rear Lower panel (Roll Pan) Custom Rear Lights
Interior :
Cosworth Recaro Front Seats, Custom Digital Boost Gauge, Cosworth 170mph Clocks, Heated front Screen,
All Parts Available.
Engine :
Transmission :
Suspension :
Brakes :
Exterior :
Interior :
