Omex 600 & 38mm Wastegate
Old Feb 1, 2013 | 05:46 PM
Langley's Avatar
Langley
Default Omex 600 & 38mm Wastegate
Omex 600 ECU, connector, couple of feet of loom, data lead, software disc and a random wrapped and labelled loom I was going to use. Comes with a zetec turbo base map loaded.
£550 posted *SOLD*
Brand new 38mm Wastegate £50 posted
Old Feb 2, 2013 | 02:10 PM
Nosmonkey's Avatar
Nosmonkey
What psi spring is installed in the wastegate?
Old Feb 2, 2013 | 03:26 PM
Langley's Avatar
Langley
I'm not too sure as I was using a boost controller so it didn't matter too much to me, but I think it is a 10psi spring.
Old Feb 6, 2013 | 08:51 PM
cossieboy599's Avatar
cossieboy599
do you still have the ecu ??
Old Feb 8, 2013 | 11:51 PM
Langley's Avatar
Langley
I should be receiving the rest of the money for it this weekend. If anything falls through I'll let you know.
IainRS1700T
Sep 25, 2015 06:44 AM
dombanks
Sep 21, 2015 08:38 PM
pabloXR
Sep 21, 2015 12:42 PM
coscor86
Sep 20, 2015 01:21 PM
Tank Mike
Sep 14, 2015 03:56 PM
