- Saftey Devices Rollcage - Corbeau Bucket Seat - Baileys - Powerflex -
Saftey Devices 6 Point Roll Cage
In mint condition, very few scratches and will also come with door crossbars which are brand new in the box uncut. Will come with all bolts and fixings. (will no fit in car with sunroof tray).
£350
Corbeau Revolution Bucket seat - Slim
Brand new seat never been fitted to a car, will come with side mounts.
£250
Zetec inlet adapter plate for EFI inlet £25
Fiesta EFI Inlet Manifold (no injectors)
£40
Powerflew Front Bush Set -
£65
Baileys Oil Breather + fitting kit (brand new)
£90
Scorpion 4" outward rolled tip exhaust (for standard CVH setup) - £80
I have a whole car to break so will update daily. I have lots more pictures of these parts just ask. Also all these parts need to be collected, Im just north of Portsmouth. 07789224407 - dont get much signal at work so may not respond till after 2:30pm.
£350
£250
£40
£65
£90
Have you got any pics of the cage in the car mate, I'm debating fitting one in my rwd Mk4 but need to see where the front and middle legs sit as I'd have to cut the 4 feet off to suit the Sierra floor I've fitted. Does it fit around the dash or does the dash need cutting/modifying??????
Ginger
Ginger
The cage mounts on the inside rear arches, back left and right floor where it meets the rear seats and mounts on a flattish bit of floor at the front. No need to cut dash as it sits infront.
