rs turbo cosworth rear wheel drive shell
Old Jan 30, 2013 | 06:40 PM
slider's Avatar
slider
Default rs turbo cosworth rear wheel drive shell
after a lot of thought im putting up for grabs my Rs turbo shell thats been converted to rear wheel drive and to take a cossie lump and suspension
i have the v5 in my name and the shell has the correct chasis number, and vin/ colour plate
this is whats done
drivers side front and rear floor pans replaced
drivers side outer sill replaced
front end has chasis rails installed and currently has mounts for a xe engine (this is what it was running before i got it)
full sierra tunnel has been welded in
boot floor has been cut out and replaced with a tub ready for a fuel tank/cell and pump
full welded rear roll cage (this cost £800)
rear suspension mounts have all been done and diff etc
still needs
n/s front pan welding in, its all cut ready to go
n/s rear floor pan needs replacing (Not rotten just badly dented)
n/s outer sill needs replacing
all the above panels are included
also needs d/s front wing replacing as this was removed to fit the full outer sill.
comes with a very good pair of mk4 doors c/w glass
mk4 turbo bonnet
rear bumper
wiring loom
steering column and wheel
complete cosworth front and rear suspension setup including subframes, arms anti roll bars and hubs
cosworth rear diff and hanger
drive shafts
sunroof
a good days welding would see 99% of this finished and ready for mock up with whatever engine you wnat to use
can be supplied as is or made into a rolling chasis
will need collecting from me12 kent,
£1000ono
simon 07789 908275
simondshaw@yahoo.co.uk
Old Feb 3, 2013 | 09:16 PM
cossie daz's Avatar
cossie daz
This looks a nice shell for someone
Old Feb 3, 2013 | 09:24 PM
retro d's Avatar
retro d
Nice project
Aug 14, 2015 07:29 AM
dal3door
Aug 13, 2015 06:55 AM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
Old ford
Jul 31, 2015 06:50 AM
