Which engine ????????
Old Jan 30, 2013 | 11:59 AM
bigup316's Avatar
bigup316
Default Which engine ????????
Got a mk 4 XE3i cab which i am in the middle of doing up.The engine is ok runs fine sounds ok its got 115k on it.Think of changing engine for something a bit newer 1.8/2.0.Been told a zetec is an easy conversion is this true do i need to change ECU if i use one of the above and is it just the inlet manifold i need to change.Don't want big power but a bit more would not be a bad thing.
Old Jan 30, 2013 | 12:23 PM
xr4x4rs's Avatar
xr4x4rs
if you fit a zetec you need to change ecu and wire in the zetec engine loom
the cvh ecu wont run the zetec engine
Old Jan 30, 2013 | 01:46 PM
escortmk3rwd's Avatar
escortmk3rwd
is it efi or mfi if its efi dont have to change loom use zetec engine and efi loom if its mfi got to use ecs or edis4
Old Jan 30, 2013 | 01:52 PM
bigup316's Avatar
bigup316
Its an efi I saw something sayin had to change inlet manifold is this right
Old Jan 30, 2013 | 03:31 PM
escortmk3rwd
my mate gav at washington makes inlet and exhaust conversion plates from zetec to cvh hes on bgay as well
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
