Bottom end components...
Old Jan 30, 2013 | 01:47 AM
C4P5I's Avatar
C4P5I
Default Bottom end components...
Hello all,
I wasn't sure which section this should go in, so very sorry if I have the wrong one.
I was wondering if someone could advise me on how much the following is worth, its all in good used con but I've been told by a reputable source its all good and has plenty of life left.
Cosworth YB 9 bolt flywheel crank shaft
two sets of YB pistons
set of rods
oil pump / pickup
crank casing
alloy sump
205 block / main end caps
dizzy with gears
Almost a complete 2WD bottom end in pieces, I guess its just missing a crank pully water pump and seals/shells/bolts. I've been watching ebay for a guide, but alot of the parts never come up on their own...
thanks very much in advance!
Old Mar 20, 2013 | 08:59 PM
mark r's Avatar
mark r
id say selling apart at least 500 -600 notes
Old Mar 21, 2013 | 02:44 PM
C4P5I's Avatar
C4P5I
Thanks for the reply fella, will stick these up for sale now I know whats resonable, cheers for that! Had no idea how much they were worth, I've had them a long time sat around...
If they are worth that I might see if I can swap them for a basic 5.0 302 that needs rebuilding, or at least a complete bottom end, happy days.
Old Mar 21, 2013 | 02:46 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Bare in mind you need to be a gold member to advertise, and for What's it worth threads!
Just a heads up
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
