what is the max bhp throw standard 4x4 running gear?
as above whats the max bhp 4x4 sierra cosworth standard running gear can handle??
thanks for your help
BHP is not the limiting factor, its torque that will cause you drivetrain issues.
my Old T34 car was running around 420lb/ft and smashing std 4x4 boxes and diffs for fun,. this was on the T34 55s package at around 380bhp.
hmm thats no great new then as i was planing to use a t34 .63 , siemens 55s , bd14/bd8 cams, and was planing to use one of your msd 380 off the shelf chips .
so i am rather stuck now as i dont like the idea of killing the gearbox a diffs
The T34.63 is better for drivetrain than the T34.48 i was using as the power is more linear, the .48 is a real low down punchy turbo.
You may be ok on the .63, but its a little like russian roulette, your next time on boost may just be the gearboxes last, you never know lol.
The T34.63 is better than the T34.48 i was using as the power is more linear, the .48 is a real low down punchy turbo.
bet the uprated boxes are mad money too
It does depend how you drive, we do plenty of the T34.63 55s conversions, most are fine on the std boxes its just an unknown how long they will last, they are certainly at the limit up there.
My Bara box was around 5k i think.
and yep thats about the price i was thinking lol
I had a standard 4x4 gearbox go with 270bhp@wheels! But to be honest that had a hard life for 15-20K miles with a T34.48 and greens.
Think alot is to do with how you treat it, I dont have much mechanical sympathy.
as i said i will be mainly driving normally giving it the odd boost
think i will go ahead with my plans the if it dies down spec
thanks for everyones help
Anything more than 300 ft/lbs through a standard box you're on borrowed time, but saying that as said its a lot to do with driving style, I had 400ft/lbs on a standard box and organic plate have just removed it and I'm selling the gear kit on the bay as its still in working condition.
Have just had my gearbox built using the oppliger big tooth kit and have gone for the ap 6 paddle, best value for money box on the market imo
Luciano
Luciano
3rd gear is how to kill your 4x4 box
I broke a gearbox and rear diff on my t34.48, got the car mapped by MSD on a t34.63 and fingers crossed haven't had any failures (I drive the car a lot harder now!). I do have a Bara box and front thickwall'd ATB though.
why 4x4 mate if your not an aggresive driver 2wd is fine and when you do want to go sideways which you will want to do lol you can.
and you wont have to cut the halfmoons out of your front chasis for the driveshafts.
With over 360-370 hp and associated torque, the box should be ticking time bomb waiting for the one hard launch to kill it.
By the way, how easy it's to break a diff without doing any hard launches? Only fast road use but no launches? And to add, yes I've broken my center VC by doing few donuts on a 100k mile car, it has about 300 lb-ft.
as for lanches the car wont be doing that as thats how you break things on mostly any car , will just be normal road use with a bit of ass kicking now and agein , no launches and wont be on any track
Luciano
Luciano
good luck with the build do a build thread for it and keep us updated mate.
this seems like good money..
http://bbs.rsownersclub.co.uk/showthread.php?t=501400
but as said above opplinger seem to have it on lock at the moment as far as good gearbox setups go
Lottery, there are some people that have had them last for ages and a lot of people, that have had them last for a short space of time.
I've smashed loads of them, never at launch, so thats a common misconception that people make, although launching it may contribute to wear it matters more higher up the rev range when your boosting it, in higher gears at max torque. Bottom line is even if you don't launch it, there's no guarantees it won't break.
Also just to add I have never broken a front diff, from reading feedback on the escos forum it appears they are substantially more reliable than is made out to be. Again, not saying it is bullet proof, but the box is way more likely to go bang first.
Since I have done a bit of research into the boxes I shall share what I have found as the fault cause. Basically the MT75 box/bearings are susceptible to wear, and what happens is that over time this creates movement of the shafts in the box, given that helical gears create a thrust force, i.e. naturally push apart from each other when engaged, then this is essentially what destroys the gearbox. With a straight cut gear you don't generate the same axial loads and therefore (theoretically) it is less likely to fail. Principle is the same for most boxes, the gears only break becasue the bearings fail or parts are worn, the broken gears are just a result of the play in the box.
Also compare this to a turbo, when you destroy this, it's not usually anything but the fact the bearing is shot and it has contacted the inside of the housing becuse of the excessive movement of the shaft
You ain't got to cut the half moons out I never have .
Never had no problems never hit the chassis rails
It's lowered 25mm too.
