Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Mk4 fesa fuse is being a b@#tard
Old Jan 28, 2013 | 09:32 PM
fiestajosh92's Avatar
fiestajosh92
Default Mk4 fesa fuse is being a b@#tard
I have a mk4 fiesta ztech and when I use main beam fuse for left bulb keeps blowing but right side is fine I have changed fuse and bulb and still blows so tried a bigger fuse and it's still being a f#cker. Plz help
Old Jan 29, 2013 | 08:12 AM
cossiejay's Avatar
cossiejay
there is a problem somewhere,putting in a bigger fuse is risky the fuse is rated for a reason putting in a higher one can set the car on fire it sounds like the wire has worn and is earthing out somewhere
Old Jan 29, 2013 | 08:17 AM
RichieST's Avatar
RichieST
Unplug headlight then try it. If it doesn't blow then you know the problem is inside headlight, if it does, then you know it's a problem with the car's wiring loom somewhere. As said above, don't ever used a higher rated fuse!!
IainRS1700T
Sep 25, 2015 06:44 AM
streetracer
Sep 24, 2015 08:14 PM
roomey
Sep 19, 2015 08:40 AM
Flatlinedan
Sep 18, 2015 12:41 PM
bassboy
Sep 10, 2015 08:54 PM
