Complete rs turbo engine setup
1990 1.6 cvh mfi escort rs turbo engine, alternater, starter, inlet manifold, turbo inc manifold and -31 actuator, fuelling meter, boost hoses, full wiring loom that has been chopped at drivers cill, cross over pipe and both ecus complete with mounting brackets and standard intercooler, have pace double capacity that can be supplied for £50 extra
The engine got rebuilt in november with:
new piston rings
new big end bearings
new head gasket
New head bolts
New cambelt
New water pump
New sump gasket
New top hat valve stem seals
New lifters
Valves reground
All above parts were purchased from burton
I then ran engine in for 1000 miles then took to devil developments to get set up it managed 149.6 bhp
Since then iv done about 300 miles but have just purchased a full efi setup so hence why all this is up for grabs, engine does not smoke rattle or anything its a sweet engine
This really is a complete conversion minus gearbox and water hoses!
If you have any questions at all please ask
I may be able to pallet up but this can only be done on weekends due to work
Im after £650
new piston rings
new head gasket
New head bolts
New cambelt
New water pump
New sump gasket
New lifters
Valves reground
Im after £650
Wilsfoci
15
Mar 30, 2016 10:26 PM
track.focus'd
Aug 12, 2015 05:53 PM
Escortdriver1
Ford Focus RS Parts for Sale.
Aug 10, 2015 05:47 PM
