fuel tank breather valve sierra cosworth
Old Jan 26, 2013 | 08:39 PM
saph cos rob's Avatar
saph cos rob
swindon rsoc
Default fuel tank breather valve sierra cosworth
hi guys, since owning my 3dr ive noticed a bit of a whiff of fuel in my garage (never had this with my old sapph) ive traced it coming from the vent pipe under the car, the tank has a pipe coming out of the top, runs through a valve type looking cylinder up by the filler neck (see pic below) then vents off underneath - after taking this valve (?) off ive found it to be completly hollow? im sure my old one on my sapph had some sort of ball in it, if i look though the inlet pipe i can see daylight out of the other end? how are these things ment to work, as you can see from the pics its sealed and looks like its never been tampered with
Old Jan 26, 2013 | 08:44 PM
JOHNDQ's Avatar
JOHNDQ
If its the same as on my RS2000 if you try blowing through upright you can but turn it on its side and you won't be able to blow through any more
Old Jan 26, 2013 | 09:17 PM
saph cos rob
swindon rsoc
nah, i can blow through it any angle lol, i thought it may have been some sort of carbon canister that all the internal substance has erroded away?
steerfromdarear
28
Jan 29, 2016 06:14 PM
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
ekjim
Aug 17, 2015 08:57 PM
155lee
Aug 14, 2015 11:21 AM
taylora1409
Aug 12, 2015 12:06 PM
