EFI/ENGINE/Autospecialist parts
Parts clearout due to a change of plans. Prices do not include postage.
EFI inlet manifold,modified to take cosworth throttle body,complete with fuel rail, FPR, and water temp sensor adaptor and Vac fittings £75 Cosworth Yellow injectors included, not shown in pic.
Cross over pipe modified for cosworth throttle body/efi set up. £25
Crank sensor set up, Bottom pulley, trigger ring (adjustable) spacer washer, crank sensor and mount. £75
Phase sensor set up, bracket and phase sensor disc. £35
Engine, Had a top end rebuild before I bought it, EFI head, Kent 35 Cam, New S1 water pump, New ford timing belt, can be supplied with S2 water pump. £350
RS turbo flywheel freshly skimmed. £35 cost me that to have it skimmed.
RST Standard pistons done aprox 70k no signs of any damage. £20
EFI coil pack and bracket £25
EFI ECU bracket (fits behind the centre console) £15
EFI leads bought new form ford. £50
10mm silicon plug leads. £25
Autospecialists heatshield. £20 + postage (postage £11.25)
Never been used, fitted.
Clear indicators mk3 escort, done 0 miles. £15
Rover inlet ideal for zetec turbo conversion. £50
