focus rs mk1 brembos, discs and pads, done just under 1000miles
Bodger of Blackburn
as title really, i have had them fitted to an xr2 so come with all fixings for those too.
the callipers themselves have had some trimming done, but does not affect fitment or performance. £230
Bodger of Blackburn
as long as there is an internal diameter of 378mm IIRC then they'll fit
but this needs to be pretty much up to the edge of the rim, the rota's tapered in to 368mm i think which is why the other edge has been shaved to accommodate this.
a mate has offered to let me trial fit a brembo and frs disc behind my comp th's, so as soon as i get a hub and a cv joint to go and get trial fitting stuf, i will be in touch if the results are positive dude. if its anywhere near to a possibility, i may take the risk and get a deal on the go with ya
Bodger of Blackburn
my spacer was 5mm, but really only needed a 3mm for clearance.
If it helps I used these on a MK5 Escort using ET35 muti spokes, wheel cleared fine but needed 5mm spacer between hub and disc so it didn't catch the lower balljoint
It's probably the price mate, ie seen them come up on the RSOC for £100 for just te calipers & they fly out.
I actually want them, just come at the wrong time.
Hold out and you might get the price.
Nov 3, 2015 04:08 PM
