cosworth parts for sale
a pair of escort cosworth 4x4 front uprights , these are in perfect working order but could do with a clean . they will need new bearings etc fitting before use and they do not come with the drive flanges.
£180 the pair
a pair of 2wd cosworth rear bearing carriers that have been machined out by dome motorsport to accept wrc wheel bearings , stub alxes and drive flanges. the bearing are in very good condition and a pair of bearings alone cost £300 so these are a bargain.
again these could do with a clean and paint.
£100 the pair
amal valve with hoses , switch and a stainless steel cover from auto specialist. this was used on my zetec turbo to switch from low boost to high boost and is in perfect working order . the code on the back is e37 if this means anything to anyone. the stainless cover cost £30 alone
£50 for the lot
fiesta turbo chrome bonnet hinges , £55 new from auto specialist , never been fitted so brand new
£20
sapphire cosworth bonnet plates in stainless steel from auto specialist , a few surface scratches but nothing that couldnt be ploished out
SOLD
if you need any part numbers etc just pm me as iam always on here so should be pretty quick in answering any questions.
its first come first served and i will not mess people around.
delivery can be arranged but i would like if people can collect as some items like the front uprights and bearing carriers are heavy
DELIVERY WILL BE EXTRA AT BUYER EXPENSE
CHEERS PAUL
£180 the pair
£100 the pair
£50 for the lot
£20
SOLD
CHEERS PAUL
I did think that but they look different shapes, so was thinking it was a side and a centre plate in the pic? Woild rather ask before buying. Are these the same for both 2 and 4 wheel drive bonnets, as I don't have the vents being 2wd.
cheeRS
cheeRS
I think the 2wd and 4wd bonnet is the same for the 3 pieces but I can only find auto specialists for 4x4 and 3door so I might be wrong
rog
Sep 4, 2015 12:10 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
