Part query
Quick one - is this the nut or collar that holds the level sensor in to the side of a 2wd header tank?
http://www.ebay.co.uk/itm/Ford-Sierr...80901978454%26
I think it is the blank for a sapphire 2wd as the 3 door and sapphire have the same tank but only the 3 door has the level sensor the sapphire one is blanked off with the part in the pic then the screw on nut
