Ford Range This section is for other models in the Ford range.
1997 escort van fuse questions
Old Jan 15, 2013 | 06:05 PM
bluntys1rsturbo's Avatar
bluntys1rsturbo
Boost addict
Default 1997 escort van fuse questions
hi guys hoping someone can help, my rear lights apart from indicators have stopped working on my van its defo not the bulbs as these were replaced recently, so im thinking the fuse might of given up, do any of you know what number in the fuse box the rear lights are and what amp they are?
Old Jan 15, 2013 | 07:01 PM
STeve's Avatar
Super Moderator
if the fronts are working my moneys on the stalks to cause this as dead common on all models of mk6 escorts
Old Jan 16, 2013 | 03:04 AM
bluntys1rsturbo
Boost addict
ok thanks for the reply, ill try the quick fix first then if no luck try the stalks.
Old Jan 16, 2013 | 02:40 PM
bluntys1rsturbo
Boost addict
so i tried the fuses still no joy, popped see my mate a gt motorsport who tells me they are known for blowing fuse boxes so hes put me onto an auto electrician to have a look this saturday.
Old Jan 16, 2013 | 03:24 PM
Fordmad!'s Avatar
Fordmad!
My old mk6 went through 5 stalks in 6 years. Take the stalk off and spray with contact spray.
Also the back light connections are terrible on these as i was forever having problems with the rears.
Do the same with the rears give all the contats a good clean and a play about. Thake the connector off the rear lights and check the pins arnt bent.
They can blow fuse boxs as mine did and had no headlights. Just take fuse box off dead simple and get another from scrappy be Ł15/20 max!
If you need anymore help just say!!
Old Jan 16, 2013 | 03:58 PM
bluntys1rsturbo
Boost addict
thanks alot appreciate you taking time to help out, is the stalk easy to take out? also what contact spray should i use?
Old Jan 16, 2013 | 05:09 PM
Fordmad!'s Avatar
Fordmad!
Yes, 2 screws on the top cowling either side of hazard warning switch if i remember rightly bothe phillips.
Then there is one screw on the top holding the stalk in.
I just used the spray from halfords.
Id check the rear light connections aswell as the stalks before going down the fuse box route as they are easier to check. Rear lights usually leak and rust the connections.
Old Mar 11, 2013 | 07:34 AM
phil barnes's Avatar
phil barnes
can anyone help I got stopped last night by the men with blue flashing lights because mine went mental when i press the brake pedal with the lights on my near side lights go out any ideas
Old Mar 11, 2013 | 07:53 AM
Fordmad!'s Avatar
Fordmad!
Id say its a poor earth. Take the earth off and clean connection that will sort it
Old Mar 11, 2013 | 07:56 AM
phil barnes
will do got pulled as i rallyed round the country lanes at 2.30 in the morning so was glad they were decent coppers
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Mxkid
Aug 31, 2015 10:02 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
