Non Ford parts & other stuff for sale If its not for a Ford, or even not car part... this is the room to sell it!! Starting a topic requires you to have purchased a gold membership.
Rust buster epoxy kit
Old Jan 14, 2013 | 10:56 AM
Steve Escos's Avatar
Steve Escos
Default Rust buster epoxy kit
As title ,epoxy kit to solve rust problems
this is the 5l kit so will be enough to do a full floor inside and out. Epoxy colour is black.
See website http://www.rust.co.uk/products/categ...chassis-paint/
£60 delivered
Steve 07725238098
Epoxy Mastic is a high build, high solids two pack (has a base and hardener) Epoxy paint coating for the renovation and protection of rusting and pitted steel exposed to severe environments. Epoxy Mastic can be applied successfully over wire brush cleaned steel and still offers the same exceptional performance as coatings applied over blast cleaned steel. Its finish is as hard as iron but flexes with the steel. See photo,s at the foot of this page of a customers VW restoration.
Epoxy Mastic will not flake, peel or blister - even under water. Resists oils, salt water and mechanical damage. Tough penetrating coating that is more flexible than the steel itself. Has six times the penetration and adhesion of single pack products. Does not contain any harmful isocyanates.
So how does it work?
Epoxy Mastic is a two component Epoxy paint composed of nanoscale corrosion protective pigments in short chain molecules with very low surface tension.
This allows the paint to flow into all of the pits and troughs on the steel's surface, ensuring a tough penetrating primary bond.
This is the best kind of bond you can get with a paint finish.The high build epoxy forms a super strong protective barrier over the corrosion inhibiting pigments that hug the steels surface Excellent penetration and adhesion within a high build coating equals exceptional mechanical strength.
Why can't other paints do this?
Single pack paints (paint without hardener) used to protect steel against rust are the most common products. These products have standard sized pigments bound in long chain molecules and as such tend to lay over the pits and troughs on the steel's surface because of their high surface tension, the larger pigments are not able to collect to form a tight pigment matrix. This allows voids to form beneath the paint's surface,the thin film of the coating is not able to offer sufficient barrier protection over the high points on the steels profile, rust pockets form in the voids, the paint blisters and moves onto the next void and so on. The system flakes, peels and blisters.
This scenario cannot happen with Epoxy Mastic using a primary bond. They also tend to have less solid content. This means that the peaks on the steel's profile are soon exposed to the atmosphere and once again rust forms in the void and the system breaks down. Epoxy- Mastic's high solids content of 83% means that the finished dry film thickness is on average 30% thicker than the best single pack paints available.
What is the finish like?
Epoxy Mastic can be brush or spray applied like any other paint. It is supplied with Epoxy thinners to reduce viscosity when painting smaller components. It can be painted over or left alone.
It really is the complete answer, a high performance paint finish that has no equal. It's iron hard when cured but more flexible than the steel its coating. By spray the finish is flat and smooth. By brush or roller you may see some application marks.
Old Jan 14, 2013 | 07:22 PM
cossie891's Avatar
cossie891
Mmm tempted
Old Jan 14, 2013 | 07:32 PM
cossie891's Avatar
cossie891
Mate do you need to use a etch primer before use or will this act like a etch
Old Jan 14, 2013 | 07:40 PM
Steve Escos
My understanding is that it will act as an etch and once cured can be painted straight over.
Old Jan 14, 2013 | 07:46 PM
cossie891's Avatar
cossie891
Ok I will have a good think about this
Can you ship it?
Old Jan 14, 2013 | 07:47 PM
cossie891's Avatar
cossie891
Stupid me just read it properly lol I get a
Old Jan 15, 2013 | 06:41 AM
cossie891's Avatar
cossie891
1 more question sorry mate do you know if this will be any good as a etch for a gearbox and a diff?
Old Jan 15, 2013 | 09:03 AM
coswurv's Avatar
coswurv
Read the link he's put, it tells you everything on there
Old Jan 15, 2013 | 09:20 AM
cossie891's Avatar
cossie891
Can't mate as on my phone like its any of your business
Old Jan 15, 2013 | 09:38 AM
Steve Escos
I guess so. I will add the info from the site to my first post.
Old Jan 15, 2013 | 11:29 AM
cossie891's Avatar
cossie891
Steve will txt you now
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
