Cosworth Parts
Jan 12, 2013 | 06:50 PM
Cosworth Parts
4x4 Samco / SFS silicone boost hoses £50
Alloy strut brace with ignition amp bracket attached £40
Brand new T3 K&N cone filter with fitting kit £40
30psi black faced boost gauge £20
Sapphire alloy door sill trims £20
2wd standard intercooler £20
4x4 standard intercooler £30
4x4 flywheel £20
Part 4x4 engine loom £40
3dr passenger headlight £25
4x4 auxiliary belt tensioner and bracket £25
Jan 12, 2013 | 06:54 PM
Im currently bidding on set of calipers n that on ebay finishes in 50 min if i dont win i'll 110%have them wish i hadnt bidded now!
Wes
Jan 12, 2013 | 09:51 PM
Quote:
Originally Posted by
doga-ot
Wes
you can cancel bid
Jan 13, 2013 | 07:51 AM
Would you split the hoses? I would be interested in the rad top hose and one from the turbo to the header tank
Jan 13, 2013 | 04:49 PM
Hi are the intercoolers a fit for standard 4x4 pipes?
cheers jason
Jan 13, 2013 | 05:08 PM
georgie1
you can cancel bid
Unfortunatly I was winning bidder! I did try to cancel it but they wouldnt have it, shame as price I paid for calipers alone was £80 and if i'm correct them disks you have are tarox and cost £280 new!
good luck bud wish you'd put these up day earlier
WES
Jan 13, 2013 | 05:35 PM
What size pipework is on the Pro Alloy intercooler ?
Jan 13, 2013 | 05:52 PM
cossie330
cheers jason
Yes they will
Jan 13, 2013 | 06:03 PM
What make is the dump valve?
Jan 13, 2013 | 06:08 PM
Jan 13, 2013 | 07:10 PM
Jan 13, 2013 | 09:20 PM
Ill have the dump valve if its still going mate ?
Jan 23, 2013 | 09:55 PM
Jan 23, 2013 | 10:58 PM
would you take £70 for bailey oil breather.
Jan 25, 2013 | 08:57 PM
Gearbox mount
Arrived today..thanks for the fast deliverey.
Jan 28, 2013 | 06:43 AM
Dump valve received ... Many thanks
Feb 6, 2013 | 10:21 PM
Feb 7, 2013 | 01:51 PM
Anyone know what the vibration level is like with uprated mounts?
Feb 24, 2013 | 07:59 PM
Feb 24, 2013 | 08:05 PM
I'll have the k&n if still got can collect
SmudgerByName
52
Jul 28, 2016 06:14 PM
3dr cossie
11
Dec 21, 2015 03:38 PM
155lee
14
Aug 22, 2015 12:15 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
