2WD sierra cosworth ecu
Old Jan 10, 2013 | 11:44 PM
robbo9006's Avatar
robbo9006
Default 2WD sierra cosworth ecu
I have a L6 ecu.
I am upgrading to a L8.
I have seen a P8.
Is this better than a l8 or is a L8 the one I want.
Old Jan 11, 2013 | 05:34 AM
AJC's Avatar
AJC
P8 is better but your fine with a L8.
I run L8 on both my cars. Remember you'll have to change your TPS if you do this.
Old Jan 11, 2013 | 02:08 PM
William MK2 Cosworth's Avatar
As above, I have a 2wd engine and loom, and use a L8 ecu.
All that is needed is the outer wires of the tps to be switched,
(preferably use a pf09 tps)
If I am not mistaken, the same needs to be done when using a P8 ecu, anyone that knows more is welcome to correct me !!
Old Jan 11, 2013 | 04:08 PM
robbo9006's Avatar
robbo9006
So I can use a P8 ecu.
Its that I can get a P8.
Old Jan 11, 2013 | 04:15 PM
robbo9006's Avatar
robbo9006
Ok cheers the thread I put up said a P8 is better than a L8.
Its just that I can get a P8 quite cheap.
I just want to get the best I can between L8 n P8.
I will be re chipping the p8 with one of your chips.
Its early days but I fancy black siemans and the corresponding chip on a P8/L8.
would a P8 be better taking this into account.
Old Jan 11, 2013 | 04:20 PM
nixon_2wd's Avatar
nixon_2wd
L8 and P8 are equally good except you have more options on a P8 hence it will be a better option.
Old Jan 11, 2013 | 06:48 PM
robbo9006's Avatar
robbo9006
Im going for a L8.
It will be easier to tune.
Thanx all
MARKYMARKONE
Aug 20, 2015 12:55 PM
charliecosworth
Aug 19, 2015 02:00 PM
155lee
Aug 14, 2015 11:21 AM
adam151082
Aug 11, 2015 04:50 PM
