Getting flat tyre bead back on rim edge DIY.
Old Jan 10, 2013 | 06:14 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Default Getting flat tyre bead back on rim edge DIY.
Theres a massive pot hole near my house that ive had to go through at about 15 mph due to some gay cunt twatface pulling out on me.
The bang was enough to make the tyre flat. Luckily i was literally just about to pull over at home.
the tyre bead has come off the rim and pushed inwards under the weight of thw wheel so i cant pump it up to relocate the bead on the rim.
Are there any tricks to get the tyre back on the rim DIY?
ive got pry bars i can use as a makeshift tyre lever.
Foot pump cant build a pressure up like you would in a tyre shop.
Old Jan 10, 2013 | 06:20 PM
Rax's Avatar
Rax
Lighter fuel annnnnd . . . ignite LOL.
Old Jan 10, 2013 | 06:24 PM
saph4be's Avatar
saph4be
as above lighter fluid and leg it! take weight off wheel first!
Old Jan 10, 2013 | 06:27 PM
Psycho Warren
Carbon Crazy
I dont want to burn the car down
Old Jan 10, 2013 | 06:30 PM
saph4be's Avatar
saph4be
as long as you dont go silly with the fluid it will be fine but just whip the wheel off
Old Jan 10, 2013 | 06:33 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Warren, you disappoint me, i thought that would be right up your street lol
Steve
Old Jan 10, 2013 | 06:35 PM
Cosnada's Avatar
Cosnada
+1
Old Jan 10, 2013 | 06:36 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
Lighter fluid and boom, it will sort it, but keep a bit of distance if you can.
Alternative is pop wheel off and go to an airline.
Old Jan 10, 2013 | 06:39 PM
saph4be's Avatar
saph4be
i suprised warren has not rigged a small shpe charge around it to pop it back on
Old Jan 10, 2013 | 06:58 PM
Psycho Warren
Carbon Crazy
that would cut a hole through it
Rax's Avatar
Rax
I wasnt saying wash your car in it pmsl.Just put some around the inside of the rim.Tbh I looked into this when I was going to go off roading in my Shogun.There is millions of vids on blowing em up with lighter fuel etc.
Old Jan 10, 2013 | 07:01 PM
RichieST's Avatar
RichieST
The way I used to do it with aircraft tyres was to put a long ratchet strap around the centre circumference of the tyre and tighten. As it pushes the middle of the tyre in, the bead will be pushed outwards.
Same could be done with a bit of lashing tape or rope etc.
Old Jan 10, 2013 | 07:07 PM
boost monster's Avatar
boost monster
I've done this with easy start on our quad bike tyre; I'd seen it done on Top Gear and didn't know if it would work but we were at our holiday home on the Isle of Tiree and had my two boys desperate for the quad to go. It worked great and nobody got singed eyebrows!!
Old Jan 10, 2013 | 07:15 PM
BigChuck's Avatar
BigChuck
has anyone actually done the lighter fluid trick on a low profile tyre?
Old Jan 10, 2013 | 07:18 PM
cossiejay's Avatar
cossiejay
no but I have done it on a normal tyre after watching it on top gear and thinking that could be fun emptied half a can light and boom shit me to death
Old Jan 10, 2013 | 07:20 PM
cabriolet's Avatar
cabriolet
not done the lighter fluid but have used rope in the middle of the tyre with a stick thru it to act as tourniquet then footpump
Old Jan 10, 2013 | 08:08 PM
cossie891's Avatar
cossie891
This mate is defo the safest if you don't want to use fluid
Old Jan 10, 2013 | 08:12 PM
turnover's Avatar
turnover
Rachet stap works as sometimes when replacing slicks we have to do it this way
Old Jan 10, 2013 | 08:21 PM
scoooby slayer's Avatar
scoooby slayer
+1 ive done this on a iirc 23.5 x 25 tractor tyre.
Old Jan 10, 2013 | 11:10 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
the ratchet strap trick has worked for me in the past, but was using a compressor aswell fuck using a foot pump
Old Jan 10, 2013 | 11:19 PM
Chaz888's Avatar
Chaz888
Use a pumped up small bike tube lubed with washing up liquid (got to be tight on the rim to seal )it bridges the gap and pops off as the tyre inflates.
Old Jan 10, 2013 | 11:34 PM
Psycho Warren
Carbon Crazy
managed to do it without high explosives in the end bounced it around off the car for a bit and whacked it about and my mates powerful compressor was good enough to keep up with and exceed the air leak and POP it when back into place.
Old Jan 11, 2013 | 04:28 AM
Ive got some big spoons you can borrow.
Old Jan 11, 2013 | 03:46 PM
boost monster
You should never miss an opportunity to mess about with high explosives!!
Old Jan 11, 2013 | 06:03 PM
James's Avatar
James
i had trouble with a escort van tyre once, 165/80/13 or something like that, took it down ats for assistance and he beat the inner bead on with a bolster chisel and lump hammer & then inflated it no problems. I was suprised by his method but it work, not sure i'd try it on an expensive tyre though..
Old Jan 11, 2013 | 07:50 PM
orionmojo's Avatar
orionmojo
take it off and get it to a garage ( not a petrol forecourt) with a proper airline. bang it on the floor if the tyre is flat spotted and put the air in. if its pissing out bang the tyre and wheel against the floor. It will seal again and inflate as normal.
Or just try banging it off the floor whilst rotating it a few times. this has worked for me in the past, although not with low profile tyres. you need to get it off the floor though and preferably off the car to make it easier. your wasting your time with it on the deck. i've done this with lorry tyres and it works evey time. jack it up, airline in and whilst its pissing out kick the tyre as hard as you can a few times and the bead will seal.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
T666 FRS
Alloy wheels and ICE for sale
Nov 13, 2015 06:51 PM
jamie956
Sep 1, 2015 10:50 AM
Marc sierra
12
Aug 30, 2015 10:38 AM
Aug 16, 2015 07:55 AM
