03 mondeo tdci starter sqeeling.
as above and wont engage but if i put it in gear and rock it forward and back it will start and drive fine is this the starter or dmf any info welcome thanks cossie.087
Almost guaranteed to be the dual mass flywheel causing your problems Im afraid mate !
Just done mine today and was making the same noise you mention, new dual mass flywheel,clutch kit, concentric slave cylinder,and starter motor, not a cheap fix either !!!
get rid of the dmf and fit a soild one ebay sell the conversion for around £250 if I remember right lot less then the dmf and you don't have to worry about it going again
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
The Enigma
Sep 29, 2015 10:31 AM
