when fitting an oil pressure gauge do you..................
Old Jan 7, 2013 | 09:35 PM
H15 FSC's Avatar
H15 FSC
Default when fitting an oil pressure gauge do you..................
on analogue oil pressure gauge do you have to bleed oil up the pipe to the gauge, or does it just compress the air in the line.
Dan
Old Jan 7, 2013 | 09:44 PM
Puss2's Avatar
Puss2
Formerly know as Puss
No bleeding just connect it up mate
Old Jan 7, 2013 | 09:52 PM
H15 FSC's Avatar
H15 FSC
cheers mate
Old Jan 7, 2013 | 09:56 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
make sure connections are all perfect, you dont was many PSI of 100degrees oil on your leg!
RUBY123
Oct 22, 2023 12:04 PM
Chas
Sep 21, 2015 08:57 PM
mrmann
Aug 20, 2015 11:24 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
track.focus'd
Aug 12, 2015 05:53 PM
