Anyone used boora carnauba wax
Old Jan 5, 2013 | 04:34 PM
v man's Avatar
v man
Zee Germans are coming
Default Anyone used boora carnauba wax
As title really
Bought some borra wax of amazon and the results are amazing
The paint (black in colour) looks so deep and wet
Never used this type of stuff before
Very impressed with the results
Old Jan 6, 2013 | 07:20 PM
Retro Al's Avatar
Retro Al
RWD IS KING
I think its similer to harley wax,dont be fooled thinking its 100% carnauba
( sales bullshit) ,carnauba needs to be blended with other ingrediants so you can apply it as in its natural form its rock hard.
Im sure its a great wax for the money though.
Old Jan 6, 2013 | 07:59 PM
v man's Avatar
v man
This wax is rock hard in the tin
You have to rub the cloth in a circular motion to heat it so it transfers on the cloth then wipe it over the paint work and leave for a bit to cure then gently buff off
Says 100%
Maybe maybe not
Old Jan 6, 2013 | 08:57 PM
Retro Al's Avatar
Retro Al
RWD IS KING
The MYTHS of Carnauba wax
Hopefully this thread will help clear up some misconceptions about carnauba wax as it applies to the automotive detailing industry.
Myth One: My car wax is 61 percent carnauba wax by volume!!! It's the best (and only cost 2g's)!!!
Unlike the FDA which requires independent studies to make sure the labels on food are accurate, detailing companies basically answer to themselves (and their customers).
Carnauba wax is harder then concrete in natural forum must be softened with solvents. California VOC regulations have limited the aggressiveness of the solvents that can be used, but it is safe to say that no more then 28% of the wax can be carnauba wax. So how do we arrive at this number (60% or more?)
Carnauba wax can be measured many ways but it should be measured in wet volume (that is the carnauba wax should be melted into a liquid forum). In general carnauba wax is shipped in very fine flakes, which would be there DRY volume.
An example would be to fill a 20 gallon garbage can half way up with feathers, then fill the rest up with water. Because of the light density and air gaps of the feather you could potential fill the rest of the can up with 16 gallons of water (so that only 1/5 the volume is actually feathers) and proclaim that it is 50% feather by volume (if you don't state that it is dry volume) where scientifically you would be at 20%.
Also, measuring product by weight (and thus density) is more accurate. Keep in mind that the oils and solvents added to the carnauba are usually two to three times heavier then the melted carnauba, so by weight the figure would drop to 10% (or so).
It’s a play on marketing and in my opinion false advertising.
Myth Two: My wax is 100% carnauba.
Well it cannot be more then roughly a 1/3 carnauba otherwise it would be like a block of concrete. However, if we look at the percentage of the wax in the product (assuming that no other waxes are blended in like bee's wax) then it is possible to have 100% of the wax content being carnauba.
Myth Three: The carnauba in my wax is #1 Ivory White Pure Carnauba!
Automotive waxes feature #1 Yellow Carnauba. This is the highest form of natural carnauba wax and even then it is not an expensive product. "White" or "Ivory" carnauba wax does not exist, period. It is yellow (different shades of yellow depending on age) and it is either #1 or it isn't. Micro carnauba (finely milled) can look white, but in general the carnauba wax is whitened by a bleaching process or by tumbling the flakes in paraffin wax.
Myth Four: More carnauba is better
Maybe. Carnauba wax isn't exactly super reflective in natural form. It has a filmy, slightly opaque look. Medicine and gummy bears are both encased in carnauba wax and neither has a mind blowing, jaw dropping look. It is the silicone, oil, other waxes, and solvents added to the carnauba wax that produces the shine, wetness, gloss, etc. Carnauba wax does benefit from an optical illusion called "jetting". This slight distortion in the reflected light is what creates the illusion of wetness or depth on the surface, which is desirable for many people.
Keep in mind that only a small part of the look the wax produces is from the actual content of the carnauba. The rest is from the other ingredients. Also, the wax itself is rather cheap, so you end up paying more for a product that boasts of using the cheapest ingredient in the main formula.
Manufacturers spend a lot of money researching the proper amount and what type of ingredients to mix into the wax solution to achieve the desired results. If you ask your manufacturer how much carnauba wax is in the product, a good response would be enough to get the exact look and application feel to get the job done.
Myth Five: My wax is so high in carnauba that I have to warm it with my body heat and apply it by hand!!!
Carnauba wax melts around 160 degrees F. unless you are The Human Torch, you are not melting anything. When mixed into a solution that offers more durability, the melting temperature is generally raised. Certain solvents will react with human oils and soften however. Besides if your wax melts at 98.7 degrees, imagine what happens when you pull your car in the sun!
Myth Six: My wax uses natural ingredients!
Muriatic Acid and cocaine are natural ingredients as well. So is sulfuric acid.
Myth Seven: My wax cost 2g's but I get a lifetime of refills and it has all the myths listed above. It’s a great deal!
Most waxes cost between 2 to 5 dollars to make and bottle. (5 dollars being VERY expensive). What we cannot account for is the R and D that goes into the product, as well marketing, etc... However, if you pay 2'gs for a 5 dollar wax (assuming it is very expensive to manufacture), receive a 100 dollar container, and life time refills, you are not getting a great deal by my simple, mid-western logic. That means you would have 1900 dollars in product that you would have to refill 380 times to break even (minus the shipping costs each time).
DAN@ADRIAN FLUX
Insurance
15
Jun 30, 2018 09:00 PM
Adam Graham
Sep 6, 2015 06:04 AM
Rick
Concours d'élégance.
31
Aug 24, 2006 02:47 PM
Sid
52
May 9, 2006 06:35 PM
