Sierra Cosworth Brakes go hard
Old Jan 2, 2013 | 12:28 PM
robbo9006's Avatar
robbo9006
Default Sierra Cosworth Brakes go hard
The front handbrake warning light comes on and the brakes go really hard and don't work hardly.
I think its a fuse that need correcting but the Haynes doesn't seam to cover the issue.
Old Jan 2, 2013 | 12:40 PM
martysmartie's Avatar
martysmartie
You are correct, or it may be something more serious, i.e. pump etc.
The fuse is behind the passenger dash, 30A, you may find this has melted
Some clip on underneath the dash, but you may need to remove the 'lower fascia' otherwise.
The warning lamp is illuminated due to low pressure.
Martin
Old Jan 2, 2013 | 04:10 PM
robbo9006's Avatar
robbo9006
Thankyou keep up the good work with my posts.
you have been a great help.
I thankyou again.
Old Jan 5, 2013 | 05:46 PM
robbo9006's Avatar
robbo9006
I took the lower dash out.
There were numerous fuses and relays.
Is there any directions to its location.
Colours anything.
is there anything in the standard cars that are the same in the Haynes so I could get the wiring schematic looked at.
Old Jan 5, 2013 | 06:47 PM
martysmartie
Yes, they are exactly the same as lesser ABS models!
Your looking for a 30A fuse (Green) all the other electrics are for the fuel pump, ECU, heated screen etc, you can just test each fuse in situ, that will be easier than tracing wiring etc.
Martin
Old Jan 5, 2013 | 07:57 PM
johnnycortina's Avatar
johnnycortina
Had same problem on mine - fuse holder was out on its own in among lots of other wiring (green 30A) under dash on passenger side.
Old Jan 6, 2013 | 10:07 AM
Ridgey's Avatar
Ridgey
I had the same problem, but kept blowing the fuse repeatedly, ended up replacing the pump/resevior/cylinder thingy.
Old Jan 6, 2013 | 02:34 PM
robbo9006's Avatar
robbo9006
I had some time for a proper look.
I did solder all the wires that were badly connected under the dash though.
Last night had a read of the abs section.
Last thing I did , the main power with the rubber boot at the bottem of the abs had disconnected.
Simpley plugged it in.
Well sorted that and the new clutch cable snapped at the foot pedal end.
So I still have something to fix.
Old Jan 7, 2013 | 07:29 PM
Ridgey's Avatar
Ridgey
Always nice to find a simple fix
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
martynhomer01
16
Aug 4, 2015 09:55 PM
