anyone on here know how to remove front bumper on a mk4 golf
As in T'ish reg? If so there's torx bolts in each splash guard then a couple under the grille an one either side around spotlight area. Can't remember if there's any underneath tho. Then it slides into brackets on the wings.
remove the grille and you will see 3 torques drives holding the top of the bumper on.
un screw inner arch cover from the bumper, 3 or 4 torques drives screws i cant remember exactly, then there is one torques drive bolting bumper to wing.
un screw under tray if it has one, remove front bumper covers, and just double check if there is a torques in there, then just give it a tug
jessie_rs
11
Jun 3, 2019 04:57 PM
