Are 2wd and 4x4 downpipes the same?
Are after market stainless cosworth 4x4 downpipes and cosworth 2wd downpipes the same?
Will be making up my exhaust system once the engine is back and plan on using a stainless downpipe if I can find 1 second hand as I can cut the 3 bolt flange off and weld on a v-band
I'm using a 2wd manifold but a 4x4 gearbox if that makes any difference
It's only the standard downpipe I plan to use if its feasible and I can find a good second hand 1
Thanks
Marc
Thanks
Marc
To use a 4x4 down pipe on a 2wd manifold some add piece in to raise the flange higher but I've never had a problem without adding a piece in but may depend on make of exhaust.
Ah ok
Good info so far as i want to come under the box and down the nearside so il need a 4x4 item and the mod it to suit
Rich - I have a 3" v-band adapter on my turbo
So anybody got a good second hand stainless 4x4 downpipe lol
I may have a 4x4 down pipe - will look tomorrow mate
Adapter was from Turbo Dynamics mate
http://www.turbodynamics.co.uk/shop/...ge-p-2360.html
Let me know if you do mate
Thanks
Marc
Thanks
Marc
just get one make, wouldn't take much to get one tacked together and then tig'd up afterwards.
only need a couple of mandrel bends and a bit of straight pipe, got to be better than butchering a sierra item.
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
