rs turbo wiring loom advice help needed
Old Dec 27, 2012 | 03:52 PM
djgray's Avatar
djgray
Default rs turbo wiring loom advice help needed
hi guys, im building an escort turbo from just a bare shell. i need to buy a wiring loom for it. im unsure what engine to put in it cvh or zvh. im just wondering what loom to get? there seems to be a lot of mfi looms available, am i right to assume this loom wont work for a zvh conversion?
is there a certain year or mod to make it efi?
thanks for your help so far on this project
Old Dec 27, 2012 | 04:41 PM
Dubs44's Avatar
Dubs44
depends on what management you want to run, mate. its easy enough to chop the mfi loom out of a full s2 loom and splice a different engine management loom into it
iirc you could use the loom from an efi escort xr3i to fun fiesta turbo management but its bastard expensive to tune if you can find anyone to do it.
depending on what sort of power you're after, it's probably better to run cossie or aftermarket management imo
Old Dec 27, 2012 | 04:48 PM
djgray's Avatar
djgray
thanks for the reply. im not looking for massive power, around 200bhp would be great!
im after reliability more.
if i was to do a zvh or cvh could i use the mfi loom?
Old Dec 27, 2012 | 04:53 PM
Dubs44's Avatar
Dubs44
you can get 200 bhp from mfi with a few mods but it can be temperamental
if you want reliability, sack off the mfi and go efi imo. the mfi loom won't work on an efi set up
Old Dec 27, 2012 | 05:00 PM
djgray's Avatar
djgray
ok ill keep looking for the efi loom then. what sort of power can i get from the cvh without it keep breaking?
Old Dec 27, 2012 | 05:11 PM
Dubs44's Avatar
Dubs44
standard rods will restrict you to about 230-240 bhp but they will be running on their limit
check out this link as well mate
https://passionford.com/forum/ford-e...2-01-12-a.html
Old Dec 27, 2012 | 05:15 PM
djgray's Avatar
djgray
thats more than enough for me. ill just get cvh and put stronger parts in it. thank you
j.hammond1
30
Oct 31, 2021 05:28 PM
big_Rad
Sep 15, 2017 09:36 AM
col93saphcos
Aug 7, 2015 03:21 PM
jdsjojo
Aug 1, 2015 08:50 PM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
