New to escort cosworths bought one good price but need help with few issues
Old Dec 22, 2012 | 09:33 PM
tonypastie's Avatar
tonypastie
Default New to escort cosworths bought one good price but need help with few issues
Just bought a L plate mallard green for good price £8500
107,000 miles
I am new to this world I understand I have bought at the wrong end of the market but the car generally is nice etc but
She has a few issues I am of sure where to start
Runs and starts fine
Idles terrible around 2k if your unplug idle valve thing makes no difference did have a pipe missing of the inlet,manifold a fat one with a yellow ford style spring clip I put that back on made t more stable but still idles high
Got stainless with no cat no sure how mot man will like that
I bought her with no mot
Abs light on all the time bloke Said u can't fix it as no sensors available?
No cam bet cover fitted as he says the yet the belt
He didn't have the cover either
Bit gutless or laggy until it starts going suppose to be un chipped and standard
Has dump vave fitted but I can here it dumping all I here is chatter from kone fitter
I don't think it's a quick as my Ibiza fr diesel. !!!!
Battery light seems to Be on in the back ground all the time faint worse at night
Boost gauge in dash doesn't seem to so anyting but I have found a loose boost style hose in engine bay will get somebody to suck ont see if that's the pipe
Head lining is sagging in rear
Car has momo steering wheel fitted I don't like it want standard any about?
And dash clock is missing again any about
Looks like I have painted a bad picture but its nit bad really
The car was on passionford for sale mallard green
I want to stage 1 the car and generally have her driving nice and working correctly any ideas where o start
Would love to take to msd to sort out but that's a long way from Devon
Cheers in advance tony
Old Dec 30, 2012 | 12:38 PM
daz1968's Avatar
daz1968
I would start off with a good service including Cambelt change followed by all new sensors and a set up and checkover. At least you will know where you are starting from then. I don't think it should officially pass an mot without cat, but probably ways around that. Then if all ok consider modifying after that. Then as for parts missing etc its a matter of keeping eyes open on ebay and here.
The battery light on feint all the time probably means alternator on way out but not expensive to get reconditioned. Abs sensors should be available but you need to make sure if its that causi g problem. A simple test with a multimeter will identify a knackered sensor
Hopefully a bit of time and money should see it something like. How much it costs depends how much you can do yourself.
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
