Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Spray booth extraction
Old Dec 12, 2012 | 10:24 PM
daz1968's Avatar
daz1968
Default Spray booth extraction
I am thinking of setting up a spraybooth in the garage with some removable lightweight panels so can put it together when required then put it out the way when finished. It will probably be about 4.5m x 3m x 2m high. I am just a little unsure of how much extraction to use. I was going to make it positive pressure and pump air in to avoid needing expensive explosion proof fans. Then just filter an outlet and run a duct outside. Was thinking along the lines of using one of the inline fans sold for growing plants and filter the incoming air, think the 8 inch flows about 700 cubic metres per hour would this be enough to get the over spray out.
rsguy
44
Sep 29, 2015 03:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
coscor86
Sep 20, 2015 01:21 PM
