Sold
Spec R cooler with 1.1 bar dump valve welded to cold side and turbo cooler fitted to top.
No rad brackets but I'm sure Pete at spec r will sell you some
As new, mint, no damage
Sold
Head;
27mm inlets, 26mm exhaust, bronze guides, new valves, thick head, bp320 piper cams, double springs, new hydraulics, piper pullies.
bottom end;
not for sale at this time!!
turbo;
Gt3582, tial 44mm wastegate and screamer, reyland spacer and downpipe adaptor, 2wd manifold, aeroquip oil return, stainless feed, push fit AQP aeroquip water feeds, 4" samco and huge K&N
inlet;
siemese 8 injector inlet, hart plenhumm 8 60lb high impedance injectors, escort t25 throttle, billet aeromotive rail, nitrous (sold)
running gear;
bara gearbox, quaife diffs, 4x4 shafts, props
brakes,
Ap 330mm kit
wheels
8x18" mo comps
additionals
omex 710, twin amps, aeromotive fuel system, swirlpots, -8 lines, samco hoses, spec R tanks, Spec r coolers, radtec rad _+ loads more...
any questions post below or txt
bottom end;
turbo;
inlet;
running gear;
brakes,
Ap 330mm kit
wheels
8x18" mo comps
additionals
Martin, are you breaking the whole car or just the running gear?
I'm looking for a nice set of leather seats door cards and also the plastic trim that covers the heater motor in the engine bay
Hi
I'm interested in the omex 710. Can I please get a price?
Is the loom also coming with it? If so, what connectors are on the loom (ie what type sensors do they fit? Are the sensors part of the package?
I think I can see a lambda sensor, is this run into the loom & ECU or just a gauge?
What features did you use on the ECU?
What spec is the loom built to? Can I see a few photos?
Thanks.
Thanks.
Hi
Thanks.
Thanks.
Loom bespoke to car so hard to remove
Omex now sold
Everything is first come first serve. Deposits secure items!
Txts are answered quicker!!
07809624877
PayPal or bank transfer on all items or cash on collection.
and delivery on 95% of stuff
07809624877
Pointless having a huge spec car with a crap bottom end. Needs to be same or better as it is now.
Turbo, manifold, wastegate, screamer, spacer, downpipe adaptor, bailey damper, aeroquip oil return, push fit aeroquip water, braided Feed and take off adaptor, 2wd modded manifold. All done 900 miles at 10psi and 1 dyno session with 1.7bar boost for 10 mins :-(
£sold
£sold
4x4 7" Quaife ATB diff with alloy mount (£130) and drive shafts.
3000miles. 900 on this car and just over 2000 on my last sapphire. Nice condition
£sold
Hart plenhum, not the airtec one. With t25 escort 70mm throttle, idle control valve, throttle pot, ACT sensor, vac tubes and throttle cable stay from spec r
Sold
