Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Focrd Focus Brake Problem
Old Dec 6, 2012 | 06:02 PM
Zahc01's Avatar
Zahc01
Default Focrd Focus Brake Problem
Hi,
I have a 59 reg 1.6 focus dielsel, and have a problem when braking. I can hear a grinding noise if braking harsh-ish, doesnt do it when braking normally and the noise is accompanied by a nasty vibration through the brake pedal. The problem has been happening on and off for a coupleof weeks. The brakes were checked by a main ford dealer about 2 months ago.
The problem occurs either when braking going over a speed bump, on ice, or braking when going over an uneven road surface. This is making me think it has something to do with the abs, but as a complete novice this is only a guess. The brakes are great at all other times.
By coincidence the car is going into the garage for its MOT on Saturday, and I've asked them to take a look, but I'd like to have some idea beforehand.
Thanks for any help you can give me
Old Dec 7, 2012 | 07:07 AM
melinamotor's Avatar
melinamotor
Farpylee
ABS fault would be my guess as you surmise, I'm used to older fords so only really understand tone rings and sensors. I believe newer cars have magnetic ones rather than grooved. Do you have any warning lights on the dash that appear to stay on, more than likely yellow?
Old Dec 7, 2012 | 12:02 PM
Zahc01's Avatar
Zahc01
Thanks for your reply. I do look for a warning light when it happens, but nothing appears. There are no warning lights at any other time either
Old Dec 7, 2012 | 01:47 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Fouled abs sensors would be my guess.
Old Dec 7, 2012 | 08:02 PM
LewisT's Avatar
LewisT
sounds to me like its working fine, abs on any car i have driven with it, sounds like your driving on gravel and the brake peddle pulses
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
