ST 155 Mondeo problem
Hi all, got mondeo st tdci estate and its been great until saturday when whilst in some traffic i noticed it was a little jerky on throttle then dreaded flashing glow plug light. I just about got it home and plugged a scanner in which found nothing. I took egr off(euro 4 electric type)and cleaned it but wasnt too bad. Ive tried it unplugged but makes no difference. I had aa out last night and they found no faults and live data looked ok.He doesnt think its injector as the engine is still smooth just no power. I can start it easily and i can see the electric actuator move then just opens wastegate. Dont know if this is the problem or this is how the ecu limits the power. Ive had injectors go before and always bought code up. Just bought delphi fuel filter to fit tonight. Anyone any idea??
Shame these cars suffer so many stupid problems,their a great package otherwise.
My mate has just had the plug light come on his too,however it's just switched off after a few days same symptoms (albeit a 2.0tdci),maybe the quick cold snap?
Yeah its a great car,quite specced up as well with satnav,bluetooth and ford media pack in the rear. I not sure how good the aa diagnostics machine is?? Maybe another would reveal something but i dont know. I can go out to it now,start it no probs and after about 5 secs it goes limp oo err lol. Doesnt tickover rough or rattle etc
Ok cheers ill have a butchers tonight. The aa did a live reading whilst in limp mode but he said everything looked fine? Fuel pressure movin as it should,maf seemed ok. I thought it maybe actuator thing but wastegate is free and even if i unplug it it still goes in limp. i drained the old filter and diesel was clear. Cant see no swarf which i was dreading finding
this is where I bought mine from great service!
http://www.ebay.co.uk/itm/FORD-MONDE...item2578132efc
steve
steve
steve
steve
There are 3 different egr valves altogether for tdcis, make sure you get the correct one.
Sometimes water ingress causes them to reverse polarity and stay open when meant to be closed, they don't give a fault code then.
Steve
Right, my mates plugged it into his reader today and got p132a. Think this is the turbo control unit. Goin have to have another look at it tonight. I not buying a new turbo for it. He cleared it but soon as its started it comes back
The (variable) vanes in the turbine get coked up with carbon from the exhaust, which causes the actuator to sieze or not move to its full extent, this in turn damages the electronic actuator, As far as i remember Ford wants to sell you a compete turbo unit w actuator, you can pick the actuators up on the bay, i heard a rumor that there is one part that fails (the motor?) and it is realatively cheap to replace
An EGR blanking plate fixes all faulty EGR valves, EML may come on but engine will otherwise run fine, costs about a fiver (solid, stainless steel)
Can't you get stuff nowadays to "clean" the turbo vanes?
Assuming its a vnt turbo?
If you can clear it from the ecu for a bit then take it for a good blast that could help it too.
Cleaning de-coking the turbo on the car (foam cleaner "stuff" etc) often does not work, and a stripdown (turbo cartrige/ exhaust manifold ) may be nessesary the vnt mech is built into the one-piece exhaust manifold
the ST-TDCI does not have a wastegate, the vnt is used to control boost (by the ECU via the actuator) if the vnt siezes or does not function properly it may mean the engine boosts too little or too much/ is set for low or high boost/revs
From what i understand p132a is an actuator problem where as p132b is the vanes sticking in turbo. Ive got actuator off now goin get it cleaned and checked. They call this progress!
All Mk3 Mondeo ST-TDCIs (2.2s) have vnts/ variable-vane turbos, controlled either by an electronic or pneumatic actuator, euro3 or euro4 emmision compliant
Fair enough.
Sounds like cosmatt maybe on the right path by checking the actuator out first.
I changed a vnt on my merc Cdi and all it appeared to be was a normal turbo with a block plugged on the side which was calibrated to control the boost (i think),otherwise it looked identical to a normal turbo.
Hope it gets sorted fella.
Definitely check the actuator first - One of the connections goes on the circuit board. A simple resolder often fixes it. Have a look around Talkford for pics and how-tos.
Ive just cleaned it with contact cleaner and checked the little wires around the edge but they still look like they are soldered ok. Will try it later. There is some carbon swarf in there like off the motor brushes. When i start the car it moved to a position then sort of twitches about a bit then just fully opens wastegate resulting in flashin plug light and car been as flat as a witches tit. I have a vw transporter t5 and when that went in limp(overboost) it was still very driveable but this st is dangerous. It struggles to pull off and slightest incline results in 1st gear. Thanks for the help guys, ill keep you up to date on it
Sounds like its free to move.
Not sure how it works exactly in a car but my guess is it moves to the extremes of fully open/fully closed first then settles at perhaps a mid point,there's a good chance that it's missing a few readings along the scale and getting "confused".
Could even be the point that it settles is worn and giving an open circuit reading.
I'll see if I can find out some more info on it.
http://www.tdisport.com/Forum/viewtopic.php?t=8202
Found some info here plus if you google ford vnt turbo there's a yard somewhere selling just the actuator bit of the turbo if that's all that's wrong.
It seems as though it can be disconnected electrically and driven round to prove it out.
There is also this company who refurbish the electronis actuator if you dont want to tackle it yourself.
http://www.ecutesting.com/ford_monde...o_actuato.html
Right,just i quickie, i ordered another actuator today so going try it when it comes. Now will i need to clear dtc when i fitted it or will it come out of limp wrist mode on its own and i can clear it when i get it to mates garage. Thinking of getting f super for my laptop to read/clear myself very soon. Ta
It's really hit or miss tbh.
Quick update to help others out one day,blanked egr off and tried it. EML light is on but not fixed it. I will probably leave it blanked though and turn light off via scanner. I managed get a actuator off ebay from a titanium x for a very good price. It arrived this morning and fitted it...fixed!! So even though i couldnt see anything wrong with my pcb in actuator it must of been shot. Thanks for all your input guys
