Ladies Pink 10" Vibe Sub woofer & Amp
my daughter who no longer uses it so gave this to me, in perfect working order and cost just over £100 6 months back, sounded great in the car and will suit nearly all models
£40 collected from the watford/harrow area or postage will be £10 on top, I intend to use the money to buy her something in return so she does not lose out
FLI FT10A (Pink) 10" 800W Active Subwoofer & Enclosure
The design team at FLI, are consistently developing new innovative products that not only meet technical requirements but also create a stylish appearance which adds to the overall impact of any well thought out install. The NEW Limited Edition Pink Active FLI Trap, coming soon, is pre-amped and offers quick and easy installation. The FLI Trap is a brand new concept in enclosure design. The compact bass system is capable of generating tighter, deeper, bigger bass than conventional enclosures. The design offers a perfect acoustic environment for the FLI woofers, this is created by the large curved top, which greatly reduces unwanted resonance. Angled baffle boards at each end of the enclosure form a double wedge design that amplify pressure inside the enclosure to significantly increase bass output and cone control. The active amplifier has been given the exact power to drive the limited edition FLI subwoofer to its full potential, the amplifier, sub and enclosure are perfectly matched, rewarding the listener with tight accurate bass. The enclosures are trimmed in tight weave acoustic carpet finished in a limited edition pink FLI colour scheme and high quality stitched branding.
Active subwoofer bass-box with built in amp Special PINK finish design 10" Fli Frequency driver with Fli Loaded 200 Amplifier 250 Watt RMS / 800W Max Bass Boost & Crossovers built-in Dimentions: 450(L) x 300(W) x 343(H)mm.
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
davidfox280585
Shows & Track Days
Sep 17, 2015 10:09 AM
siscossie
Aug 27, 2015 09:27 PM
