Gaz Golds & other parts(Pictures added)
These parts are all from Escort Cosworth
Gaz golds in good condition springs spec up for fast road & track covered 2000 miles as you can see in the pictures there is some surface rust on the bodys the threads are clean & free & also you can see the inspection sticker is still on there
£550
Adjustable track rod ends inc rose joints & power flex bushs
£125 (could do with new seals)(sold)
4x4 Antiroll bar & power flex bushs
£55
Front Abs sensors 1 in good condition 1 is a bit mullered so it my not work
£50
I will post pictures up tommorrow
Cheers Paul
£550
£55
£50
Cheers Paul
Nov 3, 2015 04:08 PM
