Ford Range This section is for other models in the Ford range.
2002 escort van heater problems
Old Nov 27, 2012 | 05:07 PM
craigbed's Avatar
craigbed
Default 2002 escort van heater problems
My 2002 escort van heater blower was only working on highest setting but has now stopped working altogether. The fuse had blown so i replaced it and that one blew aswell. However i tried another fuse(same rating) and it hasnt blown but the heater blower still isnt working. Any suggestions?? how do i locate the heater resistor???
Old Nov 27, 2012 | 05:30 PM
STeve's Avatar
Super Moderator
sounds like the heater resistor pack or fuse box
Old Nov 27, 2012 | 08:00 PM
craigbed's Avatar
craigbed
have been told that by a couple of different people but dont know where the resistor pack is. Any ideas?
Old Nov 27, 2012 | 08:48 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
top of blower motor, behind rubber trim, infront of wipers, under plastic scuttle pannel
Old Nov 27, 2012 | 08:56 PM
craigbed's Avatar
craigbed
thanks for your help pal ill
have a look in tomorrow
Old Nov 27, 2012 | 09:38 PM
martysmartie's Avatar
martysmartie
A faulty resistor pack is whats causing it not to work on the other speeds!
However, the fact it's blowing the fuse means either the motor is partially siezed or you have a short, more likely the former!
Sometimes water can make it's way in to the motor which causes the problems.
Martin
Old Nov 28, 2012 | 08:18 AM
STeve's Avatar
Super Moderator
some models the resistor pack can be found inside the cabin area nr matrix(b1tch place)
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
druidgetafix
Aug 15, 2015 10:22 AM
